naeyaerttesting 0 Posted October 15, 2024 Posted October 15, 2024 Hello I have a weird issue. Some users can connect via Emby Connect App to my server fine - others can not connect. When I test connection to remote WAN access to port 8096 it works fine and all users can login fine. It's just some users Emby Connect wont let through. Please help - tearing my hair out
Abobader 3484 Posted October 15, 2024 Posted October 15, 2024 Hello naeyaerttesting, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Robnaeyaert 22 Posted October 15, 2024 Posted October 15, 2024 Emby Connect wont let some users (some not all) though on my server BUT when I use the WAN Remote address it logs users in correctly. Is there an issue with Emby Connect that is causing this issue? It's only some users (I can login fine with Emby Connect via my mobile). Help Please
seanbuff 1353 Posted October 15, 2024 Posted October 15, 2024 As per the link above, you need to provide a lot more information. 53 minutes ago, naeyaerttesting said: It's just some users Emby Connect wont let through. What exactly happens when they try?
pwhodges 2023 Posted October 15, 2024 Posted October 15, 2024 The first thing to try to fix this is to delete the user's Connect email address in Emby, save the user, then add it again to remake the Connect connection. Paul 1
pwhodges 2023 Posted October 15, 2024 Posted October 15, 2024 It's preferred not to make multiple threads for the same issue, please. I already replied in your other thread - but the first thing to try is to remove the user's Connect email address and then readd it to remake the Connect connection. Paul
