Happy2Play 9811 Posted October 14, 2024 Posted October 14, 2024 6 minutes ago, firefox1970 said: Both flags ?? I only change <CollapseVideoFolders> to false Deleting and recreating the library should have set per library option for CollapseSingleItemFolders to false but the only way to check now in is via the api doing a /library/virtualfolders/query as the /root/default/libraryfolder options.xml is no longer used. API link at the bottom of dashboard. But depending on your setup is blocked to localhost/https connections per browser CORS settings. The is a workaround with browser flags mentioned in several topics. First section of this guide covers it as it was about the Collections library before it was readded.
firefox1970 12 Posted October 14, 2024 Author Posted October 14, 2024 I can Open ServerName:8096/emby/openapi See attached File openapi.txt
firefox1970 12 Posted October 14, 2024 Author Posted October 14, 2024 Now its working. After change the <CollapseVideoFolders> to false I need delete and recreate the library again 2 1
