GuyBee 2 Posted October 11, 2024 Posted October 11, 2024 I have a movie with AC3 5.1 that's plays fine on a tablet. But if i I connect (very cheap) Bluetooth headphones and try to play that same movie it fails and says there was an issue etc. Is this a bug? Is it just that the headphones can't handle the audio codec, and better quality ones would? Would love some insight. Thanks!
GuyBee 2 Posted October 11, 2024 Author Posted October 11, 2024 Error in logs "audiitrack init failed 0 config... Audiosink$initializationexception"
Solution GuyBee 2 Posted October 11, 2024 Author Solution Posted October 11, 2024 I can fix this by using an external player (vlc or just player do the job).. but I'd love to know why thats needed and if I can make it not be necessary.
Luke 42242 Posted October 21, 2024 Posted October 21, 2024 @GuyBee Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
