DarinM 11 Posted October 11, 2024 Posted October 11, 2024 I've been running Emby now for a little under a year and things have been good until this latest release. It starts out fine, but after videos have been streamed for a while the load average on the system jumps. Here is a load average example: top - 20:35:40 up 12 days, 23:41, 1 user, load average: 60.00, 60.00, 60.00 Tasks: 287 total, 2 running, 285 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.1 us, 0.1 sy, 0.0 ni, 99.8 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 63529.2 total, 3031.1 free, 1003.0 used, 59495.1 buff/cache MiB Swap: 15260.0 total, 15259.5 free, 0.5 used. 61425.8 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1784893 emby 20 0 9258336 368100 91228 S 0.7 0.6 1:23.27 EmbyServer Doing systemctl restart emby-server clears it out and brings the load average down. Last night when I checked on it load average was 174. This is a Rocky Linux 8 system with 64 GB memory. The processor is AMD Ryzen 5 5600G. It also has an RTX 3050 for transcoding. I had restarted Emby just before 6PM tonight and the load average was like this by 8:35PM. Any suggestions or info are appreciated. embyserver-63864189406.txt
Carlo 4561 Posted October 11, 2024 Posted October 11, 2024 Hi, I didn't see anything in the log file. Everything seemed to be running very quick as well. PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1784893 emby 20 0 9258336 368100 91228 S 0.7 0.6 1:23.27 EmbyServer What are you trying to show here? Looks very low to me.
DarinM 11 Posted October 11, 2024 Author Posted October 11, 2024 8 hours ago, Carlo said: What are you trying to show here? Looks very low to me. load average: 60.00, 60.00, 60.00 This is the issue. It only happens when something is played. Restarting emby takes it to 0 where it normally sits.
Q-Droid 1011 Posted October 11, 2024 Posted October 11, 2024 Something isn't right there. top - 20:35:40 up 12 days, 23:41, 1 user, load average: 60.00, 60.00, 60.00 <-- this Tasks: 287 total, 2 running, 285 sleeping, 0 stopped, 0 zombie <-- doesn't jibe with this %Cpu(s): 0.1 us, 0.1 sy, 0.0 ni, 99.8 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st <-- or this Do you have other utilities you can use to check, like sar or vmstat? They should all get their info from the same place but these numbers don't make sense. You would want to capture this while Emby is active IF it is indeed the one causing the problem. The value 60 across the board is suspect and would reflect a very busy host.
DarinM 11 Posted October 11, 2024 Author Posted October 11, 2024 Sar is showing this: 08:00:00 AM all 0.28 0.00 0.33 0.16 0.00 99.23 08:10:00 AM all 0.10 0.00 0.29 0.09 0.00 99.52 08:10:00 AM CPU %user %nice %system %iowait %steal %idle 08:20:00 AM all 0.21 0.00 0.27 0.07 0.00 99.46 08:30:00 AM all 0.11 0.00 0.24 0.04 0.00 99.62 08:40:00 AM all 0.10 0.00 0.21 0.03 0.00 99.66 Average: all 0.12 0.00 0.19 0.02 0.00 99.67 Not showing much.. The system is not very busy at the moment. What I have figured out is that the load average goes up when transcoding is done. Is there a way to get a thread count from the Emby process?
Q-Droid 1011 Posted October 11, 2024 Posted October 11, 2024 (edited) Is that from the same timeframe? The load average in top is a rolling 1, 5 and 15 minute value while sar is listing 10 minute intervals. There is no time period in your list with high usage which should be there if you had a load of 60 over 1, 5 and 15. In my opinion a very consistent value of 60.00 for all time slots is nearly impossible. The load average from top is the number of processes in the run queue waiting for CPU. Meaning that on your host there should be 12 on CPU and another 60 (more like another 48) waiting and the usage would be reflected as 0% idle, a high %user and high %system because of the overhead of so many processes queued up for work. Is your OS up to date? The kernel isn't very new. I'm on openSUSE so the commands might be slightly different. To show the threads when emby is the runtime user: top -H -u emby ps -Lf -u emby -U emby Edited October 11, 2024 by Q-Droid Correcting the load average meaning.
DarinM 11 Posted October 11, 2024 Author Posted October 11, 2024 Sorry not from the same timeframe.. I've been trying to recreate the issue.. I've found that watching transcoded material causes it. The OS is Rocky Linux, so Red Hat based and yes, it will use an older kernel. Not bleeding edge like Ubuntu. Here's current info: top - 10:59:50 up 13 days, 14:05, 1 user, load average: 21.87, 19.39, 14.30 Here's output from top -H -u emby: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2640958 emby 20 0 6726148 354412 92460 S 0.3 0.5 0:00.04 .NET ThreadPool 2531976 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:01.08 EmbyServer 2531977 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 EmbyServer 2531978 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 EmbyServer 2531979 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 EmbyServer 2531980 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 EmbyServer 2531981 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.05 .NET Finalizer 2531983 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.32 .NET Long Runni 2531984 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 EmbyServer 2531985 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET Network Ad 2531987 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.34 .NET ThreadPool 2531989 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.47 Kestrel Timer 2531990 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.09 .NET Sockets 2531994 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:01.08 .NET Timer 2532004 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532005 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532006 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532007 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532008 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532009 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532010 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532011 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2532040 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.00 .NET File Watch 2609923 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.07 .NET ThreadPool 2610004 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2610005 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2610739 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2616825 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.06 .NET ThreadPool 2616867 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2617611 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.01 .NET ThreadPool 2618030 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.03 .NET ThreadPool 2618415 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2618456 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2624595 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.04 .NET ThreadPool 2624596 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.02 .NET ThreadPool 2624597 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.12 .NET ThreadPool 2626267 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2631752 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.08 .NET ThreadPool 2632565 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.02 .NET ThreadPool 2632576 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.02 .NET ThreadPool 2633378 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2636445 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.17 .NET ThreadPool 2637653 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.03 .NET ThreadPool 2638428 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.02 .NET ThreadPool 2638437 emby 20 0 6726148 354412 92460 D 0.0 0.5 0:00.00 .NET ThreadPool 2641704 emby 20 0 6726148 354412 92460 S 0.0 0.5 0:00.02 .NET ThreadPool And output from ps -Lf -u emby -U emby: # ps -Lf -u emby -U emby UID PID PPID LWP C NLWP STIME TTY TIME CMD emby 2531976 1 2531976 0 48 08:41 ? 00:00:01 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531977 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531978 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531979 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531980 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531981 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531983 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531984 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531985 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531987 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531989 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531990 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2531994 0 48 08:41 ? 00:00:01 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532004 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532005 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532006 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532007 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532008 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532009 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532010 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532011 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2532040 0 48 08:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2609923 0 48 10:21 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2610004 0 48 10:21 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2610005 0 48 10:21 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2610739 0 48 10:22 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2616825 0 48 10:29 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2616867 0 48 10:29 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2617611 0 48 10:30 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2618030 0 48 10:31 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2618415 0 48 10:31 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2618456 0 48 10:31 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2624595 0 48 10:39 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2624596 0 48 10:39 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2624597 0 48 10:39 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2626267 0 48 10:41 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2631752 0 48 10:48 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2632565 0 48 10:49 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2632576 0 48 10:49 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2633378 0 48 10:50 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2636445 0 48 10:54 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2637653 0 48 10:55 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2638428 0 48 10:56 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2638437 0 48 10:56 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2641704 0 48 11:00 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2641753 0 48 11:01 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2641755 0 48 11:01 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe emby 2531976 1 2641756 0 48 11:01 ? 00:00:00 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe Restarting emby clears the high load average..
Q-Droid 1011 Posted October 11, 2024 Posted October 11, 2024 Your best bet is to capture all of this while it's happening and also include the relevant emby server log, ffmpeg logs and hardware detection log. The info after restarting Emby showing idle procs and no CPU time on them isn't useful. Start with a clean slate and reboot the server first. 1
