Failed recordings restart solution
Many thanks to @joekingcoolfor perfecting these apps. I've been using them for about 10 months, since the first release, and they work really well. Just wondering if it would be possible to incorporate them into Emby? Maybe this could be modified to allow Emby to restart a failed recording without restarting the server entirely thereby not interfering with other simultaneous recordings that have not failed? Thoughts....
December 2023:
here is all apps updated.
the monitor now checks for 3 errors. then verifys that no matter what that recording status is set to inprogress so it trys again when emby starts back up.
1. "Media sequence changed unexpectedly" = MSC
2. "maybe the m3u8 list sequence have been wraped" = SHBW
3. "Seek to start failed" = STS
the recording cleanup, now refresh's the guide after it starts back up
the config file has a few changes, so make sure you update your current config file.
let me know if these work or any fail :)
Recording_Monitor.exe 2.91 MB · 1 download Recording_Cleanup.exe 2.9 MB · 1 download Recording_Folder_Cleanup.exe 2.89 MB · 1 download Recording_Joiner.exe 2.89 MB · 1 download config.txt 301 B · 1 download
  • Thanks 1
