VicMoore 755 Posted October 10, 2024 Posted October 10, 2024 The TV platform in VirtualTVExample allows channels to be populated with both "TV" and "Radio" content. I have mastered building "TV" channels. Now I am trying to build a "Radio" Channel. I tried populating the Channel with audio-based content, but that caused a "Cast" error when one of the audio shows in the TV Guide was clicked. What kind of content does a Radio Channel require and what format should it be in? Vic
Luke 42234 Posted October 11, 2024 Posted October 11, 2024 Hi ,I believe it was for audio content, yes. What was the error?
VicMoore 755 Posted October 11, 2024 Author Posted October 11, 2024 @LukeI recreated building a radio channel with audio content and it worked. The unusual thing about it is that it worked both when the channel type was set to "TV" or "Radio". In my first test, when playing the channel failed, I received an error message saying that the played content could not be cast to the required type. I must have made a mistake some where. Luke, thanks for the help. Vic 1
VicMoore 755 Posted October 11, 2024 Author Posted October 11, 2024 (edited) @Luke , the audio channel plays correctly on the Emby Web Client but does not play on the Samsung TV (Android) client. I tried both "TV" and "Radio" channel types. I get an "Unable to tune to channel at this time" error. Vic Edited October 11, 2024 by VicMoore 1
VicMoore 755 Posted October 12, 2024 Author Posted October 12, 2024 @LukeDo you have any idea why my audio channels do not play on Emby clients for TVs? They only play on the Web Client. Vic
Luke 42234 Posted October 12, 2024 Posted October 12, 2024 1 hour ago, VicMoore said: @LukeDo you have any idea why my audio channels do not play on Emby clients for TVs? They only play on the Web Client. Vic Log example?
VicMoore 755 Posted October 12, 2024 Author Posted October 12, 2024 @LukeThe logs for playing via the Web-Client and via the Samsung TV are attached below. Vic Log-web-client.txt Log-SamsungTV.txt
Luke 42234 Posted October 12, 2024 Posted October 12, 2024 How does it compare with our standard android app?
VicMoore 755 Posted October 12, 2024 Author Posted October 12, 2024 Dont know. Dont know what the standard android app is. Vic
Luke 42234 Posted October 12, 2024 Posted October 12, 2024 9 minutes ago, VicMoore said: Dont know. Dont know what the standard android app is. Vic Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
VicMoore 755 Posted October 12, 2024 Author Posted October 12, 2024 OK I will do that ASAP. Once I do that what do I do with the app. Do I use it on my PC, or do I load it onto the TV? Vic
VicMoore 755 Posted October 12, 2024 Author Posted October 12, 2024 I have it installed and I am testing it now Vic
VicMoore 755 Posted October 12, 2024 Author Posted October 12, 2024 (edited) @Luke, on the standard android app everything works OK, except all programs always start at the beginning. That problem might not yet be fixed. Thanks for the help... Vic Edited October 13, 2024 by VicMoore 1
