podonnell 48 Posted October 10, 2024 Posted October 10, 2024 One of my titles does not allow me to fast forward or choose the chapter. Doing so just results in nothing happening. I have three devices: A SHIELD, and LG C3, and an LG G3. Oddly, the issue only happens on the G3. What information can I provide about the title or from logs that can help identify why this is happening on the G3? Thanks!
Luke 42234 Posted October 11, 2024 Posted October 11, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
podonnell 48 Posted October 11, 2024 Author Posted October 11, 2024 (edited) Here is the embyserver log from the play session I just tested. Started movie, attempted to fast forward and rewind -- the timing bar does move but the video does not. Clicking chapters as well does nothing. thing no fast forward or chapter.txt Edited October 11, 2024 by podonnell
visproduction 335 Posted October 11, 2024 Posted October 11, 2024 Try a test demo video that has all the metadata correct and a valid timeline. Also I see that perhaps h.264 inside .mkv is not supported on some LG TV's. What is the video codec for your test file. If you have a mp4 file, maybe you should test with video as h.264. When you test with a .mkv video, then use h.265. I am guessing some older LG TV's just doesn't like mixing codecs with some video wrapper types. Your .mp4 media might be wrapped inside .mkv to allow a lot of multiple subtitles. That's another weak point, that I don't think TV's like to deal with that combination. These are just guesses. You did not include details or an example video. Just find online demo test videos, otherwise you might be running around in circles trying to fix something in your TV settings or thinking it's an Emby issue, when it's your media that has problems. Also playing back on a 3rd party video player is not a good test. VLC and others will fix things on the fly. Playback to TV or browsers are not so forgiving. Hope that helps. https://www.lg.com/us/support/help-library/lg-tv-supported-video-codecs-for-connected-usb-devices--20153095976198 1
podonnell 48 Posted November 5, 2024 Author Posted November 5, 2024 This just started happening on every episode in a series that I started. It also appears to once again be limited to my internal LG G3 Emby having the issue. SHIELD on the same TV works just fine. The skip intro button as well as any attempts to fast forward or rewind do not work at all.
Luke 42234 Posted November 6, 2024 Posted November 6, 2024 Hi, we’ll take a look at it. Thanks for reporting. 1
ikatsuke 1 Posted November 10, 2024 Posted November 10, 2024 Just to add to this topic I am having the same thing, if more logs are required let me know file.txt 1
