Arrgh 6 Posted October 5, 2024 Posted October 5, 2024 Is there a way to stream my Reolink IP camera's to Emby? I just want to be able to see a video stream of my choice really quick. The idea is to be able to pull up the stream real quick on my TV when I hear a knock at the door or when I want to stream my kids baby cam while they sleep. Any thoughts?
Solution Carlo 4564 Posted October 5, 2024 Solution Posted October 5, 2024 Hi, if the camera allows setting up a URL that you can get to work in VLC then you can likely use that in Emby via the IPTV plug-in installed from the plugin catalog. A number of users do this. I don't know personally know if Reolink cameras do this or not as I don't own any of them Carlo
