bruor 43 Posted October 5, 2024 Posted October 5, 2024 I have an IPTV source that has OTT (over the top - direct distribution via app to smart TVs etc) feeds. Is there any way for us to add/search for these in Emby's (Gracenote) guide data?
Carlo 4561 Posted October 5, 2024 Posted October 5, 2024 Hi, I'm not sure exactly what you are asking. Could you please elaborate a bit more on this? Thanks, Carlo
bruor 43 Posted October 5, 2024 Author Posted October 5, 2024 A specific example: I have an m3u playlist for DAZN which is not on Cable/Satellite/Broadcast, but is internet direct. Seems like Emby guide data is keyed to location and provider. Wondering if it is known if Gracenote has guide data for this provider, and if there is a way to access/map it is emby.
Carlo 4561 Posted October 6, 2024 Posted October 6, 2024 Hot ya, No, it will not have guide data for a service such as DAZN. DAZN uses Widevine DRM protection which Emby doesn't support. Carlo
bruor 43 Posted October 6, 2024 Author Posted October 6, 2024 And even though I have the feeds, I can't find out if Gracenote even has the guide data ¯\_(ツ)_/¯
Luke 42237 Posted October 7, 2024 Posted October 7, 2024 I think it has some lineups for things like direct TV internet channels that might help.
