MASTERTV 0 Posted October 2, 2024 Posted October 2, 2024 I subscribed to 75 devices, I wanted to know if it is possible to add more than 75 subscribers
Gilgamesh_48 1243 Posted October 3, 2024 Posted October 3, 2024 1 hour ago, MASTERTV said: I subscribed to 75 devices, I wanted to know if it is possible to add more than 75 subscribers What are you doing? Are you trying to become a new "Netflix?" 75, in itself, seems excessive for sharing. But, to make an attempt at answering your question. The "75" refers to devices active not to subscribers (also a suspicious way to refer to friends and family) and you can have, I think as many people as you want able to connect you just cannot have more than 75 devices connected. At least that is the way I understand it.
yocker 1369 Posted October 3, 2024 Posted October 3, 2024 Picture having to transcode to 75 at once. O_o
Carlo 4561 Posted October 3, 2024 Posted October 3, 2024 Hi, You would probably be better off setting up a second server with a new Premiere License. You could then expand that if needed. This would cut the overall I/O down and allow for more transcoding if needed.
Solution ebr 16306 Posted October 3, 2024 Solution Posted October 3, 2024 Hi. 75 is the largest plan we offer and you cannot "stack" or add licenses together. Please also note that your license to use Emby is for personal use only. Thanks. 1
