Jakiesun 0 Posted October 1, 2024 Posted October 1, 2024 Thank you for updating the function about button to control speed in iOS version. Maybe you can kindly update the same function in TvOS and Android TV. Besides, you can consider make the button bi-functionally. For example, the app called " SmartTube Next" on Android TV make the button has function: 1. When it's short pressed, it fast switch normal speed and preset speed 2. When it's long pressed, the speed can be chose by a menu. Thank you all.
Luke 42239 Posted October 1, 2024 Posted October 1, 2024 HI, it's something we can look into, although hard to promise. Space is at a premium in TV layouts, so adding another button usually means having to take one out, and those decisions can be difficult.
