marianomaki 22 Posted October 1, 2024 Posted October 1, 2024 alguien sabe como poner pin , para una biblioteca entra de pelis xxx , no soy capaz de hacerlo gracias
seanbuff 1356 Posted October 1, 2024 Posted October 1, 2024 10 minutes ago, marianomaki said: Does anyone know how to put a pin, for a library of xxx movies, I'm not able to do it thanks There's no way to PIN protect a specific library. You can only control access to libraries via users who can have a PIN set.
Luke 42239 Posted October 1, 2024 Posted October 1, 2024 Hi, please see Users please let us know if this helps. Thanks!
marianomaki 22 Posted October 1, 2024 Author Posted October 1, 2024 no no soy capaz de hacerlo , hago desaparecer la bibloteca pero no es lo que quiero , quiero que el usuario la vea pero cuando quiera reproducir le pida pin , asi que no se seguire mirando por hay a ver
seanbuff 1356 Posted October 3, 2024 Posted October 3, 2024 On 10/1/2024 at 11:24 PM, marianomaki said: I want the user to see it, but when they want to play it, it asks for a PIN, so I won't keep looking around to see. That is not currently supported. Based on your user configuration - users will either have access to the library, or not.
seanbuff 1356 Posted October 3, 2024 Posted October 3, 2024 On 10/1/2024 at 11:24 PM, marianomaki said: I want the user to see it, but when they want to play it, it asks for a PIN, so I won't keep looking around to see. Looks like there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
