danielromerohn 0 Posted October 1, 2024 Posted October 1, 2024 Every time a user logs in on different devices, English appears as the default language and the backdrops are disabled. Does anyone know how to force these settings from the server using a plugin or xml file? Sincerely
Happy2Play 9811 Posted October 1, 2024 Posted October 1, 2024 All client setting are independent to each other and are not controlled by the server. 1
danielromerohn 0 Posted October 1, 2024 Author Posted October 1, 2024 How can I have an Emby Connect account linked only to the server and not also to the user? So that all users use the same Emby Connect to enter the server and then choose their user manually? Sincerely
Luke 42239 Posted October 10, 2024 Posted October 10, 2024 On 9/30/2024 at 11:49 PM, danielromerohn said: How can I have an Emby Connect account linked only to the server and not also to the user? So that all users use the same Emby Connect to enter the server and then choose their user manually? Sincerely Hi @danielromerohnan Emby Connect account is linked to a user on your server. There is no way to link it to just the server. What you should do is give them the address of your server to connect to manually, and then they can select their user after that. please let us know if this helps. Thanks.
