justinrh 266 Posted September 30, 2024 Posted September 30, 2024 Noticed this recently started. Using Firefox on Windows. Open the guide, advance a few hours, click a show to get the detail window, upon close of the detail window, the channel monikers disappear.
Luke 42239 Posted September 30, 2024 Posted September 30, 2024 Hi, yes I've seen this before (in firefox only). Haven't chased it down yet. Thanks. 1 1
sidkipper 1 Posted October 8, 2024 Posted October 8, 2024 I have a similar issue. Have been using Firefox as a client for sometime (> 1 year), but have only noticed the issue in the last couple of versions (4.8.9.0 and 4.8.10.0). Seems to occur when I scroll up and down. Good to know its got something to do with Firefox, have spent 5 mins trying to reproduce on Chrome, not triggereed the issue.
Luke 42239 Posted October 8, 2024 Posted October 8, 2024 Yea there’s probably some css feature we are using that Firefox hasn’t implemented correctly. We’ll try to chase it down. Thanks.
justinrh 266 Posted October 8, 2024 Author Posted October 8, 2024 1 hour ago, Luke said: Yea there’s probably some css feature we are using that Firefox hasn’t implemented correctly. We’ll try to chase it down. Thanks. Luke, please post the bugzilla bug you report to Mozilla. I'd like to track it. 1
justinrh 266 Posted December 13, 2024 Author Posted December 13, 2024 @LukeI searched Mozilla's bugzilla DB for this bug and didn't find one using keyword "emby". Did you report the issue via some other channel?
Luke 42239 Posted December 13, 2024 Posted December 13, 2024 I have not filed an issue because that is not as easy as you think. I can't just open a ticket and say there's an issue in the Emby web app. They will want a standalone test page that isolates the issue in as minimal of fashion as possible. That's more work than you think, and if you don't do it, then they will just reject the issue. We are using a lot of complex css features and I think it is the combination of all of those things that is causing this. It is probably creating a scenario that isn't covered in their test cases.
justinrh 266 Posted October 2, 2025 Author Posted October 2, 2025 Looks like this is fixed in Fx 143.03! 1
justinrh 266 Posted November 15, 2025 Author Posted November 15, 2025 The problem is back after Emby server updated to 4.9.1.9.0!
Luke 42239 Posted November 18, 2025 Posted November 18, 2025 On 11/15/2025 at 1:13 PM, justinrh said: The problem is back after Emby server updated to 4.9.1.9.0! Hi there, what exactly is happening?
justinrh 266 Posted November 18, 2025 Author Posted November 18, 2025 3 hours ago, Luke said: Hi there, what exactly is happening? Scroll up ... (to the first post)
