turtlejay 0 Posted September 27, 2024 Posted September 27, 2024 Hello. I've searched the forum and read a bunch of threads and I can't seem to find an answer. I recently bought an S95C and paired it with a q990c sound bar. When I play anything with Dolby Atmos from emby it automatically transcodes the audio. I've read here that native TV apps won't passthrough uncompressed 7.1 but every other app on the TV will l. Disney+, Netflix etc can all do it. So why is emby transcoding?
GrimReaper 4895 Posted September 27, 2024 Posted September 27, 2024 11 minutes ago, turtlejay said: I've read here that native TV apps won't passthrough uncompressed 7.1 but every other app on the TV will l. Disney+, Netflix etc can all do it. So why is emby transcoding? Streaming apps are likely using DD+ as underlying audio format, as opposed to TrueHD which you're trying to play. 2
turtlejay 0 Posted September 27, 2024 Author Posted September 27, 2024 Thanks for the answer. That makes sense.
FrostByte 5453 Posted September 27, 2024 Posted September 27, 2024 For a list of compatible audio/video codecs see the chart in the back of your user's manual. Anything not on that list will need transcoding. If your file has an alternate compatibility audio track it's always best to preselect it first before clicking Play. 2024 TV specs: https://developer.samsung.com/smarttv/develop/specifications/media-specifications/2024-tv-video-specifications.html
SamES 1084 Posted September 30, 2024 Posted September 30, 2024 On 28/09/2024 at 02:04, turtlejay said: Thanks for the answer. That makes sense. This might also be useful, it is the same issue for both LG and Samsung. Atmos on LG TV | Emby Documentation
