NickGib 0 Posted September 27, 2024 Posted September 27, 2024 I just tried to open my emby and all those on the screen is enter manually and sign out of connect? I signed out of connect and then signed back in and it showed the same thing. Not sure what to do?
Abobader 3484 Posted September 27, 2024 Posted September 27, 2024 Hello NickGib, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42184 Posted September 27, 2024 Posted September 27, 2024 Hi there, are you trying to connect to your own Emby Server, or someone else's?
ebr 16306 Posted September 27, 2024 Posted September 27, 2024 Hi. It sounds like you removed your server (or you were removed from it).
NickGib 0 Posted September 27, 2024 Author Posted September 27, 2024 I’m not sure? I didn’t remove any server, don’t even know how to do that. All I know is I opened up my app and the screen said enter manually or disconnect from connect.
Gilgamesh_48 1243 Posted September 27, 2024 Posted September 27, 2024 Do you have a server of your own. That is do you own the media or are you using somebody's else's. If you have your own server then that is where you fix the problem but, if you don't, you need to contact whoever you are getting the content from as the server is theirs. Emby does not provide either content or streaming service. It just provides the means to stream your own content. 1
