PartlyCloudy 1 Posted September 25, 2024 Posted September 25, 2024 I want to start of with this, im am new to emby. So, when I was adding my first library , it says, "The directory '/media/ts82924001/Archive' cound not be found." I noticed that it says that I need to give emby rwx permission. I am not sure how to do that with emby. I did it with jellyfin, but I am not sure how to do it with emby.
guunter 49 Posted September 26, 2024 Posted September 26, 2024 (edited) Do a ls -l on that directory in terminal to find out the group that owns that folder. Then add the Emby user to the group. sudo usermod -aG groupname emby Edited September 26, 2024 by guunter 1
PartlyCloudy 1 Posted September 26, 2024 Author Posted September 26, 2024 10 hours ago, guunter said: Do a ls -l on that directory in terminal to find out the group that owns that folder. Then add the Emby user to the group. sudo usermod -aG groupname emby All of the folders say that they are in the emby group, but it still does not work. https://pastebin.com/jeaY1ELm
TMCsw 259 Posted September 26, 2024 Posted September 26, 2024 8 hours ago, PartlyCloudy said: https://pastebin.com/jeaY1ELm First please post screen shots directly here, not only is it allowed it’s encouraged. Next how is this drive mounted? /etc/fstab ? (preferred) Then what does this command show? nami -mo /media/ts82924001/Archive/emby
PartlyCloudy 1 Posted September 27, 2024 Author Posted September 27, 2024 (edited) 19 hours ago, TMCsw said: Next how is this drive mounted? /etc/fstab ? (preferred) /dev/sdb1 Also, it is a new error now, screenshot attached. emby has full rwx permissions as well. 19 hours ago, TMCsw said: Then what does this command show? nami -mo /media/ts82924001/Archive/emby It gives and error, screenshot attached. Edited September 27, 2024 by PartlyCloudy
guunter 49 Posted September 27, 2024 Posted September 27, 2024 Is this direct attached storage then? What way did you install Emby Server btw? I would not do snap if it was.
TMCsw 259 Posted September 27, 2024 Posted September 27, 2024 typo, i meant namei -mo /media/ts82924001/Archive/emby Is this a UBS drive?
PartlyCloudy 1 Posted September 28, 2024 Author Posted September 28, 2024 5 hours ago, TMCsw said: Is this a UBS drive? External HDD 5 hours ago, TMCsw said: namei -mo /media/ts82924001/Archive/emby The outcome of that is attached
PartlyCloudy 1 Posted September 28, 2024 Author Posted September 28, 2024 5 hours ago, guunter said: Is this direct attached storage then? What way did you install Emby Server btw? I would not do snap if it was. I installed Emby because Jellyfin just kinda broke on me. It wont show new media after full library scans and even after full reinstall. Also, it is an external HDD btw.
TMCsw 259 Posted September 28, 2024 Posted September 28, 2024 20 minutes ago, PartlyCloudy said: Also, it is an external HDD btw. Then you need to do this and then: https://pimylifeup.com/raspberry-pi-mount-usb-drive/ Yes this is about pi but it is Deb like..
PartlyCloudy 1 Posted September 28, 2024 Author Posted September 28, 2024 18 minutes ago, TMCsw said: Then you need to do this and then: https://pimylifeup.com/raspberry-pi-mount-usb-drive/ Yes this is about pi but it is Deb like.. So, i already have it mounted, like it works with everything else
TMCsw 259 Posted September 28, 2024 Posted September 28, 2024 4 minutes ago, PartlyCloudy said: So, i already have it mounted, like it works with everything else HOW? Just because you see it , means mothing Plz post /etc/fstab
PartlyCloudy 1 Posted September 28, 2024 Author Posted September 28, 2024 8 minutes ago, TMCsw said: HOW? Just because you see it , means mothing Plz post /etc/fstab Alrighty, I completed all of the steps now. 1
PartlyCloudy 1 Posted September 28, 2024 Author Posted September 28, 2024 4 minutes ago, TMCsw said: Good! are you still having problems? Yeah, same error. Also, I just wanted to say, thank you for all of your help so far.
guunter 49 Posted September 28, 2024 Posted September 28, 2024 5 hours ago, PartlyCloudy said: I installed Emby because Jellyfin just kinda broke on me. It wont show new media after full library scans and even after full reinstall. Also, it is an external HDD btw. I just meant docker,snap, or .deb? Or flatpack
Q-Droid 1011 Posted September 28, 2024 Posted September 28, 2024 9 hours ago, PartlyCloudy said: What Linux distro? Only root can get to ts82924001. Permissions are needed for access on every directory along the path. chmod o+rx /media/ts82924001 /media/ts82924001/Archive
PartlyCloudy 1 Posted September 28, 2024 Author Posted September 28, 2024 6 hours ago, guunter said: I just meant docker,snap, or .deb? Or flatpack I installed it with .deb
