mrdoowah 0 Posted September 25, 2024 Posted September 25, 2024 I started to get messages that I needed to upgrade my server. I'm on a Mac, the server is on a QNAP TS-453D NAS and was running 4.8.8.0 (although I didn't discover that until later). I downloaded Intel/AMD 64-bit and installed. My iPad still demanded an upgrade. I eventually removed the app from QNAP and reinstalled. My iPad continues to demand an upgrade and my Mac goes to black when I open Emby. Help! And thanks.
Luke 42239 Posted September 26, 2024 Posted September 26, 2024 HI, that's odd. Can you please attach the emby server log from when this happened? How to Report a Problem Thanks.
mrdoowah 0 Posted September 26, 2024 Author Posted September 26, 2024 Hi - after a lot of attempts to resolve I discovered that the solution was to restart the server. At that point it no longer demanded an upgrade and I got access. Only problem now is that in the attempt to fix the problem I removed Emby from the server and lost path to my files. I have a QNAP NAS with another QNAP attached. Problem is I can't find the path and all the online suggestions involve lots of code and other things. I'm a designer on a Mac (although a very old designer) and all I need is a way to see the complete path that I can use for rebuilding libraries. Can you point me towards something that will help out? Thanks for this.
mrdoowah 0 Posted September 26, 2024 Author Posted September 26, 2024 I went to the server, Apps and removed and then reinstalled Emby. When I reopened Emby there was no longer any info on movies, it was blank.
Luke 42239 Posted September 28, 2024 Posted September 28, 2024 On 9/26/2024 at 6:47 PM, mrdoowah said: I went to the server, Apps and removed and then reinstalled Emby. When I reopened Emby there was no longer any info on movies, it was blank. What exactly do you see? Can you please attach the Emby server log? How to Report a Problem Thanks.
mrdoowah 0 Posted September 28, 2024 Author Posted September 28, 2024 I had removed Emby and installed the newest version which is beta and it it no longer saw any previous info. Log is attached. Emby log.txt
Luke 42239 Posted October 9, 2024 Posted October 9, 2024 On 9/28/2024 at 6:58 PM, mrdoowah said: I had removed Emby and installed the newest version which is beta and it it no longer saw any previous info. Log is attached. Emby log.txt 4.09 MB · 1 download @mrdoowahwhat do you mean exactly by no longer saw previous info? Were screens blank? Were you taken to the server startup wizard?
