d00zah 152 Posted December 19, 2024 Posted December 19, 2024 I have the same redundancy w/ TV Series on a smaller scale. Happy to test against my setup when available.
dves010 1 Posted December 19, 2024 Posted December 19, 2024 On 10/6/2024 at 4:06 PM, d00zah said: Fair disclosure... I am also using the 'Strm Extract' plug-in in addition to yours. Maybe off-topic for now, but did you ever looked at: StrmAssistant? Using Strm Extract also, but I'm not totally happy with it. StrmAssistant/README.en.md at mod · sjtuross/StrmAssistant · GitHub
d00zah 152 Posted December 19, 2024 Posted December 19, 2024 6 minutes ago, dves010 said: Maybe off-topic for now, but did you ever looked at: StrmAssistant? Using Strm Extract also, but I'm not totally happy with it. StrmAssistant/README.en.md at mod · sjtuross/StrmAssistant · GitHub Aside from including unwanted tags (cosmetic), it does what I need it to. Mind if I ask what your issues with it were?
dves010 1 Posted December 19, 2024 Posted December 19, 2024 4 minutes ago, d00zah said: Aside from including unwanted tags (cosmetic), it does what I need it to. Mind if I ask what your issues with it were? Unwanted tags - indeed. And no "correct" info at the TV Shows; they said it not work well for TV Shows? True? (And plugins without any settings/info...not a fan of globally) I'm installed StrmExtract yesterday again, give it another try. After I will try StrmAssistant also.
d00zah 152 Posted December 19, 2024 Posted December 19, 2024 (edited) To be honest, looking at a few series, it looks pretty clean... all the codec info I want. No tagging, but that could just be the targets themselves. If only StrmExtract had some filters. Please share your impressions of StrmAssistant re: Movies. Edited December 19, 2024 by d00zah
dves010 1 Posted December 19, 2024 Posted December 19, 2024 Ok, will wait for the StrmExtract to be finished...maybe it is ok this time. Will let know if StrmAssistant is also working or maybe a better choice afterall.
jelum 36 Posted December 29, 2024 Author Posted December 29, 2024 @d00zah@dves010unfortunately, logic is implemented slightly differently for TV shows, and I didn't find a proper way to merge inter-library. sorry
dves010 1 Posted December 30, 2024 Posted December 30, 2024 On 12/29/2024 at 11:38 AM, jelum said: @d00zah@dves010unfortunately, logic is implemented slightly differently for TV shows, and I didn't find a proper way to merge inter-library. sorry Ok sadly, but thanks for the try! i can code myself a little. Wich program section I can look at, mainly?
jelum 36 Posted January 2, 2025 Author Posted January 2, 2025 On 12/30/2024 at 7:21 PM, dves010 said: Ok sadly, but thanks for the try! i can code myself a little. Wich program section I can look at, mainly? I mainly checked in two places: * ILibraryManager#MergeItems(BaseItem[]) can merge only videos - used for movie * MediaBrowser.Controller.Entities.TV.Series#CreatePresentationUniqueKey(BaseItem[], LibraryOptions) - the only place where I found a usage of the config EnableAutomaticSeriesGrouping (this is a flag used in library configuration). I'm less familiar with a "PresentationUniqueKey" meaning, it looks like it's unique per library (in that case will not help for the issue). So I don't want to break something that will emerge too late. Since the code is "closed" it will take too long to find all pitfalls.
Ronstang 294 Posted January 26, 2025 Posted January 26, 2025 I want to try this but am wondering is it something that can be uninstalled and your database reverts to how it was before? I have a huge amount of physical files and a large number of libraries for testing purposes. Is it possible to run this on just one library that has multiple directory stores and subdirectories? I have a library that I know what and where all the dupes are so it would be easy for me to test the results?
bakes82 167 Posted January 27, 2025 Posted January 27, 2025 5 hours ago, Ronstang said: I want to try this but am wondering is it something that can be uninstalled and your database reverts to how it was before? I have a huge amount of physical files and a large number of libraries for testing purposes. Is it possible to run this on just one library that has multiple directory stores and subdirectories? I have a library that I know what and where all the dupes are so it would be easy for me to test the results? Using common sense would say create a backup of the db, and the just replace if it you have issues ....
Ronstang 294 Posted January 27, 2025 Posted January 27, 2025 9 minutes ago, bakes82 said: Using common sense would say create a backup of the db, and the just replace if it you have issues .... Yes but the last time I tried this I spent the better part of 3 days getting my emby back where it was because the backup did not work. And yes, I followed the tutorial.
bakes82 167 Posted January 27, 2025 Posted January 27, 2025 there is a tutorial for finding the .db file and pressing ctrl c and ctrl v?
Ronstang 294 Posted January 27, 2025 Posted January 27, 2025 I added this plugin into my test emby server on a different machine and it did nothing. How do I get it to work? It shows up in the plugins in the emby settings but it is doing nothing. I only have 2 movies in a test library with two different versions of each to make library scans lightning fast but still nothing.
jelum 36 Posted January 29, 2025 Author Posted January 29, 2025 On 1/27/2025 at 12:38 PM, Ronstang said: I added this plugin into my test emby server on a different machine and it did nothing. How do I get it to work? It shows up in the plugins in the emby settings but it is doing nothing. I only have 2 movies in a test library with two different versions of each to make library scans lightning fast but still nothing. Those movies should have at least one similar ID—the same TMDb, or IMDb, or kinopoiskId, or traktId, etc.
Luke 42250 Posted March 9, 2025 Posted March 9, 2025 Automatically merging movies by Movie Db Id will be a built-in feature in the upcoming Emby Server 4.9 release. Thanks. 2
jelum 36 Posted March 13, 2025 Author Posted March 13, 2025 On 3/9/2025 at 9:36 AM, Luke said: Automatically merging movies by Movie Db Id will be a built-in feature in the upcoming Emby Server 4.9 release. Thanks. Is it possible to merge them using multiple (dynamic) providers? Some of my videos don't have a TMDB ID.
Luke 42250 Posted March 13, 2025 Posted March 13, 2025 1 minute ago, jelum said: Is it possible to merge them using multiple (dynamic) providers? Some of my videos don't have a TMDB ID. I don't know if that will happen right now, but I do hate to have tmdb hardcoded so yes I think that is a logical next step. Actually if tmdb id emtpy it checks imdb. Until the time is carved out to add more options to library setup to make it dynamic, I think that will work for the vast majority.
jelum 36 Posted March 13, 2025 Author Posted March 13, 2025 1 minute ago, Luke said: I don't know if that will happen right now, but I do hate to have tmdb hardcoded so yes I think that is a logical next step. Actually if tmdb id emtpy it checks imdb. Until the time is carved out to add more options to library setup to make it dynamic, I think that will work for the vast majority. You can take my code as a base for implementation - it supports multiple providers 1
besii 0 Posted July 22, 2025 Posted July 22, 2025 thanks! plugin works like a charm! are there any news or workarounds to get the same for tv shows?
Luke 42250 Posted July 22, 2025 Posted July 22, 2025 4 hours ago, besii said: are there any news or workarounds to get the same for tv shows? It is a built-in feature. No plugin needed.
jelum 36 Posted August 5, 2025 Author Posted August 5, 2025 On 7/22/2025 at 9:30 PM, Luke said: It is a built-in feature. No plugin needed. For videos? From what version? For TV series?
Luke 42250 Posted August 5, 2025 Posted August 5, 2025 2 hours ago, jelum said: For videos? From what version? For TV series? 4.9. For movie’s. 4.8 already can merge TV shows 1
dves010 1 Posted August 6, 2025 Posted August 6, 2025 22 hours ago, Luke said: 4.9. For movie’s. 4.8 already can merge TV shows But only for the same library, right?
