purger500 13 Posted September 21, 2024 Posted September 21, 2024 I am running android app on Nvidia shield Pro. I've noticed that app automaticaly resize subtitles acording to aspect ratio. For example subtitles in 16:9 video are smaller and in 2.35:1 subtitles are bigger. It's pretty annoying. Can you fix this, please? 1
Luke 42242 Posted September 22, 2024 Posted September 22, 2024 Hi there, can you please show a specific example? Thanks !
purger500 13 Posted September 22, 2024 Author Posted September 22, 2024 Hi Luke! Thanks for answering. First I need to specify that problem is present in Android app (not in Android TV app). Two examples: 1. This is 16:9 aspect ratio and subtitle is larger (this size is what I want) 2. And this is 2.35:1 aspect ratio and subtitle is smaller (too small for my taste) Automatic subtitle resize is not caused because of resolution. It is caused because of aspect ratio.
Luke 42242 Posted November 10, 2024 Posted November 10, 2024 OK we'll take a look at it. Thanks for reporting.
