denz 501 Posted September 10, 2024 Posted September 10, 2024 Any chance the tv guide WMC UI fixes can be pushed to Theater as the tv guide is still not navigating properly. When a long programme is on its' the most evident. In WMC when you click on a long programme it doesn't take you to the end you are still staying in the time you are searching in. WMC UI the guide is working as intended. I have attached a video of Theater and WMC UI. Can there be also an overlay underneath the mini tv guide as in bright videos it's very hard to see the guide. Screen Recording 2024-09-10 131752.mp4 Screen Recording 2024-09-10 132003.mp4 1
softworkz 5133 Posted September 10, 2024 Posted September 10, 2024 8 minutes ago, denz said: Any chance the tv guide WMC UI fixes can be pushed to Theater as the tv guide is still not navigating properly. When a long programme is on its' the most evident. In WMC when you click on a long programme it doesn't take you to the end you are still staying in the time you are searching in. WMC UI the guide is working as intended. I have attached a video of Theater and WMC UI. More than a dozen times, users have been asking to integrate these fixes. Another dozen goes on me. Luke has the code on his desk for a long time since; eventually he had taken two or three of those fixes, but essential parts are still missing. I cannot explain why, nor can I make any change to this for the app, I'm afraid.
denz 501 Posted September 10, 2024 Author Posted September 10, 2024 @Luke can you please import the fixes so we have a proper working guide. It's a good opportunity to have this working with the new app. Hopefully it can be fixed before the Australian tennis season starts as it is a pain in the backside to use the tv guide when the sports are on. 1
denz 501 Posted September 11, 2024 Author Posted September 11, 2024 (edited) A little cosmetic improvement that would be helpful is if the mini guide had an overlay underneath, so it is easier to read. WMC UI has it and it makes it much easier to read. Edited September 11, 2024 by softworkz added line break 2
softworkz 5133 Posted September 11, 2024 Posted September 11, 2024 (edited) 33 minutes ago, denz said: A little cosmetic improvement that would be helpful is if the mini guide had an overlay underneath, so it is easier to read. WMC UI has it and it makes it much easier to read. Most remarkable is that it's much better readable, even though the font color is just half as bright. Edited September 11, 2024 by softworkz 1
softworkz 5133 Posted September 20, 2024 Posted September 20, 2024 @denz- I've split this out into the right forum so that it doesn't get lost 1
