khohada 4 Posted September 18, 2024 Posted September 18, 2024 server version: 4.8.8.0 system: windows 11 x64 error occured when I am downloading metadata for tv anime (library type set as TV) using the plugin "Anime". username is admin. *** Error Report *** Version: 4.8.8.0 Command line: D:\EmbyServer\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.30 OS/Process: x64/x64 Runtime: D:/EmbyServer/system/System.Private.CoreLib.dll Processor count: 16 Data path: D:\EmbyServer\programdata Application path: D:\EmbyServer\system System.Xml.XmlException: System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlReader.MoveToContent() at MediaBrowser.Plugins.Anime.Providers.AniDB.Metadata.AniDbSeriesProvider.FetchSeriesInfo(MetadataResult`1 result, String seriesDataPath, String preferredMetadataLangauge) at MediaBrowser.Plugins.Anime.Providers.AniDB.Metadata.AniDbSeriesProvider.GetMetadata(SeriesInfo info, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, LibraryOptions libraryOptions, String logName, TIdType id, IRemoteMetadataProvider`2[] providers, MetadataRefreshOptions options, CancellationToken cancellationToken) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) embyserver.txtembyserver.txt embyserver (1).txt
khohada 4 Posted September 18, 2024 Author Posted September 18, 2024 as I tried to google some solution for this, I found that there were other users have encoutered the same issue back in 2019? is it still an unfix issue? is it really bad? do I have to rebuild my server from scratch?
khohada 4 Posted September 18, 2024 Author Posted September 18, 2024 more logs embyserver (2).txt embyserver (2).txt
Luke 42184 Posted September 20, 2024 Posted September 20, 2024 Hi, did you configure credentials in the plugin for anidb? if you did, try removing them. Does the issue still occur after that?
khohada 4 Posted October 1, 2024 Author Posted October 1, 2024 i can't find any credential configuration in "anime 1.5.6.0", should i install older version of this plugin instead?
Luke 42184 Posted October 22, 2024 Posted October 22, 2024 @khohadahave you updated to Emby Server 4.8.10? Has that helped?
