Didiflix 9 Posted September 17, 2024 Posted September 17, 2024 (edited) Hello there, Emby retrieved the metadata from some Collections, but I noticed for example the "007 Collection", whereas the same metadata in TMDB ( https://www.themoviedb.org/collection/645-james-bond-collection ) has 26 movies. There are however only 21 listed under collection, since the remaining 5 movies available in my library ( and identified properly under tmdbid ) are not assembled as part of it. Some other collections, like Marvel/MCU, DC, are not listed despite of having more than 3 movies in the library associated to the Collection. Is there any alternative to manually add/match the remaining entries, or add a specific collection based on your library ? I found Scan Library Files / Refresh Metadata options specifically under Collections for example, but under the Metadata Manager, only the tmdbid and other data is available ( but not the associated movie entries ). A similar situation exists with manually assembled groups - is there a way to 'ungroup' or undo an mistaken added entry from the group without remove the entire entry and recreate it ? Thank you all ! Cheers ------------------------- Details: https://www.themoviedb.org/movie/646-dr-no https://www.themoviedb.org/movie/36670-never-say-never-again https://www.themoviedb.org/movie/37724-skyfall https://www.themoviedb.org/movie/206647-spectre https://www.themoviedb.org/movie/370172-no-time-to-die Collection List: Edited September 17, 2024 by Didiflix Update image
Solution Gilgamesh_48 1243 Posted September 17, 2024 Solution Posted September 17, 2024 You can add anything you want to any collection. Just use the 3 dot menu on any show and choose add to collection and then find the collection you want to add to. I do not use auto-collections as I find them to be simply stupid and they create to many collections for the same thing. Ex. Godzilla gets, if I remember correctly, 4 or 5 different collections. I have about 250 collections and I created all of them so I know what is inside. 1
Luke 42184 Posted September 18, 2024 Posted September 18, 2024 Hi, for the movies that were not added to the collection, try refreshing the metadata on them and see if that helps get them added. 1
