WalNet76 2 Posted September 16, 2024 Posted September 16, 2024 I have two HDHR tuners in two different cities. I set both up as sources for Emby. The issue is both have a 4.1 and 5.1 channel Emby wont show both from both cities, only one at a time. Is there a way around this?
Luke 42241 Posted September 17, 2024 Posted September 17, 2024 Hi, there is currently no way around this, but we plan to provide more control over this in future updates. Thanks.
Carlo 4561 Posted October 2, 2024 Posted October 2, 2024 There is a workaround you can use but would require a small amount of manual setup. In a nutshell you export the channels of one or both of the HDHRs to an m3u file. You then edit the text file(s) with a text file to change any of the overlapping channels. Once that is done you setup this tuner using the M3U option. Try doing a Google search for something like "m3u export of HDHR tuner" or similar. Carlo
