MoLoveEnt 0 Posted September 16, 2024 Posted September 16, 2024 It took me too long to find the answer, so I am resharing so it is hopefully more prominent. OP did it with Mulvad, I use Surfshark, but doesnt seem like your VPN provider should be a factor: op: https://emby.media/community/index.php?%2Ftopic%2F108801-emby-metadata-will-not-load-with-split-tunneling%2F=#comment-1145985 Fix for Emby not collecting metadata with VPN on, even with split tunneling: Go to C:\Users\%USERNAME%\AppData\Roaming\Emby-Server\system Edit EmbyServer.runtimeconfig.json Under configProperties, go to the end of the last existing line and type a comma "," press enter and paste "System.Net.DisableIPv6": true Example: { "runtimeOptions": { "tfm": "net6.0", "includedFrameworks": [ { "name": "Microsoft.NETCore.App", "version": "6.0.29" }, { "name": "Microsoft.AspNetCore.App", "version": "6.0.29" } ], "configProperties": { "System.Reflection.Metadata.MetadataUpdater.IsSupported": false, "System.Net.DisableIPv6": true } } }
trampi3 0 Posted February 6, 2025 Posted February 6, 2025 Thank you! This is the only fix that worked for me.
Luke 42178 Posted March 12, 2025 Posted March 12, 2025 @MoLoveEnt@trampi3 Please try this instead of editing the json file: Thanks.
sa2000 689 Posted April 2, 2025 Posted April 2, 2025 Confirming that Emby Server beta release 4.9.0.43 now has a Network Setting to disable ipv6 for outgoing requests Selecting iPv4 instead of Auto would disable iPv6 1
