Scobra 10 Posted September 14, 2024 Posted September 14, 2024 I use VLC as my player since it has features that I use regularly. To name a few - Snapshot - Frame by Frame Playback - HUD (Playback Controls) hides very fast However, one thing that I wish were possible is to add audio and subtitle language on a per series basis. The way to implement this is simply by adding {audio-lang} and {subtitle-lang} to the argument list. Right now, the only arguments that can be "imported" from emby are {path}, {ms} and {Seconds}. Among these, only {path} can really be used since the other two cannot be sent from the external player back to Emby. So even if you stop in the middle of a movie/episode, it will not get that timecode. Unless I'm getting something wrong here, those two arguments aren't really useful. I think adding {audio-lang} and {subtitle-lang} would be much more useful and can be implemented the same way it does with Emby's Player, which I'm assuming uses the id for each track. As an example, I'll use VLC and MPV. VLC: {path} --audio-track={audio-lang} --sub-track={subtitle-lang} MPV: {path} --aid={audio-lang} --sid={subtitle-lang} In both these cases, {audio-lang} and {subtitle-lang} would be stream numbers/integers. My current VLC arguments are: {path} --audio-language=en,jp,any --sub-language=eng The reason I do not like this is because having eng as my audio does not select forced subtitles or "Signs and Songs". Would love to see this implemented if possible.
Luke 42243 Posted September 15, 2024 Posted September 15, 2024 Quote Unless I'm getting something wrong here, those two arguments aren't really useful. Hi, not entirely. You could start on one device, then resume with an external player. It is at least half of the puzzle.
Scobra 10 Posted September 15, 2024 Author Posted September 15, 2024 3 hours ago, Luke said: Hi, not entirely. You could start on one device, then resume with an external player. It is at least half of the puzzle. I see. I did not think of it that way. Thanks for letting me know. 1
Luke 42243 Posted September 16, 2024 Posted September 16, 2024 OK and yes ,these language params are certainly possible. 1
Scobra 10 Posted September 17, 2024 Author Posted September 17, 2024 Thanks! Also, just to clarify, it's not just the language. Sometimes there can be multiple sub tracks with the same language. Eg. English - Default (Translated Subs), English - Signs and Songs (Forced), English - SDH (English CC), etc. 1
poopsniffer 0 Posted September 14, 2025 Posted September 14, 2025 (edited) I want to use mpv with anime4k to upscale my 1080p anime but I have dual audio so this would be a godsend. The new app still doesn't support external players so I tried to use the theater app and ran into exact problem. Edited September 14, 2025 by poopsniffer
Luke 42243 Posted October 2, 2025 Posted October 2, 2025 On 9/13/2025 at 8:39 PM, poopsniffer said: The new app still doesn't support external players Hi, this is on our to do list. Thanks.
