justinrh 263 Posted September 13, 2024 Posted September 13, 2024 Is there a setting that tells Emby not to record recorded TV? I've obviously recorded a series, but nothing is logged under Live TV > Recordings.
Luke 42184 Posted September 15, 2024 Posted September 15, 2024 Hi, has the recording happened yet? Have you configured your recording folders in live tv setup?
justinrh 263 Posted September 15, 2024 Author Posted September 15, 2024 I don't understand your questions, Luke. Do you see the 32 episodes that have already been recorded?
Luke 42184 Posted September 17, 2024 Posted September 17, 2024 Have you configured your recording folders in live tv setup?
justinrh 263 Posted September 17, 2024 Author Posted September 17, 2024 Well, Emby has been recording shows ... Do you mean this optional parameter?
Gilgamesh_48 1243 Posted September 17, 2024 Posted September 17, 2024 12 minutes ago, justinrh said: Well, Emby has been recording shows ... Do you mean this optional parameter? I think that is what he was talking about. I was confused about that as I did not initially understand how it worked. I still don't fully understand its workings but I could not successfully record anything until I set that up. But I may have been doing something else wrong.
Solution justinrh 263 Posted September 17, 2024 Author Solution Posted September 17, 2024 I went ahead and actually set it to the default that was already defined in the drop list. We'll see if anything changes.
justinrh 263 Posted September 18, 2024 Author Posted September 18, 2024 All the recordings populated on the page. Should I ask why it is not populated even though Emby creates a folder and records the stuff?
