some_random_guy 0 Posted September 13, 2024 Posted September 13, 2024 My Env Linux (docker). Playback device Roku express 4k+ . When I select play back of a AV1 encoded file with opus audio. To will transcode the video h264. If I use ffmpeg to transcode audio to AAC and remux with AV1 video emby will direct play back both. When emby should only transcode the audio stream of video. Then only way I can get the AV1 + Opus combo to play is to force direct play by disabling transcode.
speechles 2062 Posted September 13, 2024 Posted September 13, 2024 (edited) Apologies. This is because HLS does not allow AV1 inside the m3u8/ts. Once you cannot direct play the item we can no longer deliver AV1 and it must be converted. What is the transcode reason when the Roku plays one of these on your server? Do you have an ffmpeg log we can see? Opus is supported on the Roku. But I suspect it is because the number of audio channels and your Roku believes it only has Stereo output and this is Opus using 5.1 surround. Can you share the ffmpeg log with us please? Thank you. Edited September 13, 2024 by speechles
some_random_guy 0 Posted September 14, 2024 Author Posted September 14, 2024 Sorry I have not had time to upload the log. I did check it and you are correct. They are encodes that I make . I will just add a compatibility track. Unless there is a different solution.
Luke 42239 Posted September 17, 2024 Posted September 17, 2024 Quote Sorry I have not had time to upload the log. I did check it and you are correct. They are encodes that I make . I will just add a compatibility track. Unless there is a different solution. Hi, if you can provide the log files then it will help us better help you: How to Report a Problem Thanks !
