EmYaj 25 Posted September 13, 2024 Posted September 13, 2024 I attached a screenshot from htop showing the issue. This process has been there for several days, and there is also a user that seems to have this particular episode "paused" (it showed up in the dashboard, pic attached below). I'm on 4.8.8.0. Not sure which log I should post since this particular instance has been ongoing for several days. Please let me know. This is the process in question (from ps -ax): 165036 ? Rl 6619:37 /app/emby/bin/ffmpeg -loglevel +timing -y -print_graphs_file /config/logs/ffmpeg-remux-8d44dfc7-9d20-41ae-aa77-23b9fd3b4654_1graph.txt -copyts -start_at_zero -f matroska,webm -ss 00:01:57.000 -noaccurate_seek -c:v:0 h264 -noautorotate -i /media/oplink/drive3/Archive/TV/The Morning Show/Season 2/The.Morning.Show.2019.S02E10.1080p.WEB.H264-PECULATE.mkv -map 0:0 -map 0:1 -sn -c:v:0 copy -bsf:v:0 h264_mp4toannexb -c:a:0 ac3 -ab:a:0 384000 -ar:a:0 48000 -ac:a:0 6 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list /config/transcoding-temp/8F8E9B/8F8E9B.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_time_delta -00:01:57.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 /config/transcoding-temp/8F8E9B/8F8E9B_%d.ts -map 0:2 -vn -an -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -segment_format webvtt -segment_list /config/transcoding-temp/8F8E9B/8F8E9B_s2.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:01:57.000 /config/transcoding-temp/8F8E9B/8F8E9B_s2_%d.vtt -map 0:3 -vn -an -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -segment_format webvtt -segment_list /config/transcoding-temp/8F8E9B/8F8E9B_s3.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:01:57.000 /config/transcoding-temp/8F8E9B/8F8E9B_s3_%d.vtt -map 0:4 -vn -an -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -segment_format webvtt -segment_list /config/transcoding-temp/8F8E9B/8F8E9B_s4.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:01:57.000 /config/transcoding-temp/8F8E9B/8F8E9B_s4_%d.vtt -map 0:10 -vn -an -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -segment_format webvtt -segment_list /config/transcoding-temp/8F8E9B/8F8E9B_s10.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:01:57.000 /config/transcoding-temp/8F8E9B/8F8E9B_s10_%d.vtt -map 0:11 -vn -an -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -segment_format webvtt -segment_list /config/transcoding-temp/8F8E9B/8F8E9B_s11.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:01:57.000 /config/transcoding-temp/8F8E9B/8F8E9B_s11_%d.vtt -map 0:44 -vn -an -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -segment_format webvtt -segment_list /config/transcoding-temp/8F8E9B/8F8E9B_s44.m3u8 -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 39 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:01:57.000 /config/transcoding-temp/8F8E9B/8F8E9B_s44_%d.vtt
Luke 42243 Posted September 15, 2024 Posted September 15, 2024 Hi @EmYajif you restart the server are you able to get this to happen again?
EmYaj 25 Posted September 15, 2024 Author Posted September 15, 2024 10 hours ago, Luke said: Hi @EmYajif you restart the server are you able to get this to happen again? Not sure how to reproduce exactly but it does happen once every few weeks
Luke 42243 Posted September 17, 2024 Posted September 17, 2024 OK once it happens again if you can please attach the most recent emby server log, that would be great. Thanks !
EmYaj 25 Posted September 17, 2024 Author Posted September 17, 2024 18 hours ago, Luke said: OK once it happens again if you can please attach the most recent emby server log, that would be great. Thanks ! Will do, I'll keep an eye on it and report back when I can get a useful log. 1
