Needabrew 2 Posted September 13, 2024 Posted September 13, 2024 Fresh install of Emby Server on Windows 7. Hauppauge 4 tuner pcie card, lifetime Premiere user. After setting up the tuner card. and adding guide data source as emby's: when I go to the channel set to map the guide data to the channel there is no pull down referring to guide data. This is the third exact same setup I have done, and the other two worked fine. Could it be the guide data server is down? Any suggestions?
ebr 16331 Posted September 13, 2024 Posted September 13, 2024 Hi. Can you please provide the server log? How to Report a Problem
Needabrew 2 Posted September 13, 2024 Author Posted September 13, 2024 Here ya go. Perhaps a browser issue? I will download another and see if it works. embyserver.txt
Luke 42237 Posted September 13, 2024 Posted September 13, 2024 3 minutes ago, Needabrew said: Here ya go. Perhaps a browser issue? I will download another and see if it works. embyserver.txt 155.93 kB · 0 downloads HI, what browser and browser version is that?
Solution Needabrew 2 Posted September 13, 2024 Author Solution Posted September 13, 2024 Never mind! Upgrading the old browser version to the latest fixed the issue! Thanks. 1
Needabrew 2 Posted September 13, 2024 Author Posted September 13, 2024 Browser was an older version of Waterfox. Updating to the latest fixed the issue. Thanks for the reply's! 1
