denz 501 Posted September 12, 2024 Posted September 12, 2024 When you select record series the red indicator on the tv guide is not of a series but only a single recording
softworkz 5121 Posted September 12, 2024 Posted September 12, 2024 That's the same in the Web App, right?
denz 501 Posted September 13, 2024 Author Posted September 13, 2024 You are right just tried it and it is a single circle. I will create a new post on the server thread.
softworkz 5121 Posted September 13, 2024 Posted September 13, 2024 Wait, I'll move this to the web app forum
denz 501 Posted September 13, 2024 Author Posted September 13, 2024 I was reporting this on the beta theater app as though it was only issue there but it is also an issue with the web app. When you click on series recordings from the tv guide only a single recording indicator shows up. The correct indicator does show up when you exit the guide and come back to it again.
Luke 42184 Posted October 20, 2024 Posted October 20, 2024 @denzare you still seeing this? In my testing I am seeing the series indicator in the guide.
denz 501 Posted October 21, 2024 Author Posted October 21, 2024 Yes I do in this example I chose series recording for Judge Judy and as you can see it is only a single indicator. Then if I go out of live tv and go back to the guide it displays it properly.
denz 501 Posted October 21, 2024 Author Posted October 21, 2024 (edited) Screen Recording 2024-10-21 091239.mp4 Video of the web client in action I am on the latest stable version of emby server Edited October 21, 2024 by denz 1
