Edição Globo 0 Posted September 12, 2024 Posted September 12, 2024 I know, its a bit easy for some, but how can i create the server link to connect to Emby Server
Neminem 1619 Posted September 12, 2024 Posted September 12, 2024 Do you know if you are connecting to the server you installed ? or are you using someone else's server ? Emby does not supply media files. Quick Start
NovelasBrasilEdiçãoGlobo 0 Posted September 12, 2024 Posted September 12, 2024 Im trying to connect to the server i installed, but i dont know what is the link. Also im on Android, not on Windows
Luke 42237 Posted September 12, 2024 Posted September 12, 2024 1 hour ago, NovelasBrasilEdiçãoGlobo said: Im trying to connect to the server i installed, but i dont know what is the link. Also im on Android, not on Windows Do you know the ip address of your server machine? Are you able to use the Emby web interface?
Aditya9503 0 Posted September 17, 2024 Posted September 17, 2024 If you are using your android device as a server, on the Home page itself you can see the IP address such as 192.68.x.x:8096. Enter the IP address on the device in the browser or Emby app on which you want to stream the media file such as Windows laptop. Make sure you are connected to the same network on both the device or else you would require "Remote Access" to be enabled in the server setting.
