denz 501 Posted September 11, 2024 Posted September 11, 2024 To me this is more a bug then a feature request however since it just seems to be ignored I will put it as a feature request hopefully with enough votes something may be done. The current navigation of the tv guide is not working as it should. In every tv guide I have used the time at the top row is fixed and can scroll up and down time is always fixed in theater it shifts. Video shows it best Theater is at top and the correct implementation of the tv guide in WMC UI is at the bottom. In theater when you go from My Kitchen Rules to Judge John Deed the time shifts so now instead of being focused on the shows at 19:30 you are now focused on shows at 20:30 Thank you Screen Recording 2024-09-11 161216.mp4 Screen Recording 2024-09-11 161451.mp4
ebr 16333 Posted September 11, 2024 Posted September 11, 2024 Is this still the case in the beta of the new Windows app?
denz 501 Posted September 11, 2024 Author Posted September 11, 2024 Unfortunately yes. I was eagerly awaiting the beta app to try it but again no improvement in this area so a big disappointment.
softworkz 5133 Posted September 12, 2024 Posted September 12, 2024 16 hours ago, ebr said: Is this still the case in the beta of the new Windows app? The new Windows app has the same code as the web app as you should know. You've seen the video (from 2 years ago) where it's fixed and there's a PR which contains all those fixes. All WMC UI apps have it included, all other Emby apps do not have it. 2
ebr 16333 Posted September 12, 2024 Posted September 12, 2024 7 hours ago, softworkz said: all other Emby apps do not have it. Actually Roku and Android TV do have logic to properly scroll along the timeline. 1
softworkz 5133 Posted September 12, 2024 Posted September 12, 2024 1 hour ago, ebr said: Actually Roku and Android TV do have logic to properly scroll along the timeline. Yea sorry for the oversimplification - the ones that you and I did are working properly, that's the bottom line
