Remi56 0 Posted November 15, 2014 Posted November 15, 2014 Hi, I installed MB server and MB Theater but MB Classic won't install on my PC. The installer starts downloading something but then I get an error of a missing file in c:\WINDOWS\ehome\ehshell.exe followed by a random number. What I tryed so far, the folder didn't exist first place so I created it, I increased rights on it by alowing full control. I switched off all anti virus, file cleaning and other soft I had. But still the same error. My system details: Nom du système d’exploitation Microsoft Windows 8.1 Professionnel NVersion 6.3.9600 Numéro 9600Mémoire physique (RAM) installée 8,00 GoPC is based on an AMD Athlon II x3 450 with AMD Radeon HD 7700 Series Attached is a picture of the error message Thanks for help.
Solution AdrianW 1058 Posted November 15, 2014 Solution Posted November 15, 2014 MB Classic requires Microsoft Media Center. Windows 8.1 doesn't come with Media Center - it's a paid add-on. Do you have Media Center? 1
Maleficarum 68 Posted November 17, 2014 Posted November 17, 2014 Looks like he has an N edition, which drops media player and probably media center along with it. Unless it allows the purchase of the wmc add on he may be have to use mbt.
Remi56 0 Posted December 9, 2014 Author Posted December 9, 2014 Yes Indeed, N version and this is a Volume version from my university (official one) which do not allows the intallation of Media Center even if you buy it... It is not an issue, it is just not allows by Microsoft for third party rights reason. I am using mbt so far. Thanks.
