dorishuntt 1 Posted September 9, 2024 Posted September 9, 2024 Thanks for Emby. It is an amazing platform that I am so glad that I've found. I have a suggestion to simplify authentication of remote clients. The use case is a family with a mix of devices in a range of areas. Users range in age from very young to very old, so everything needs to be simple to use. 1
GrimReaper 4898 Posted September 9, 2024 Posted September 9, 2024 Just now, dorishuntt said: I have a suggestion to simplify authentication of remote clients. Hi there. What would be the suggestion?
justinrh 267 Posted September 10, 2024 Posted September 10, 2024 Maybe he is saying the suggestion is for Emby to simply it.
Luke 42245 Posted September 10, 2024 Posted September 10, 2024 On 9/9/2024 at 4:38 AM, dorishuntt said: Thanks for Emby. It is an amazing platform that I am so glad that I've found. I have a suggestion to simplify authentication of remote clients. The use case is a family with a mix of devices in a range of areas. Users range in age from very young to very old, so everything needs to be simple to use. HI, what aspect of authenticating do you think could be improved?
adminExitium 356 Posted September 12, 2024 Posted September 12, 2024 I’m not sure how feasible it is, but an option I like on other apps is scanning a QR code on a new device that is presented from an already logged-in device. It can also be used vice versa to authenticate on a new device by scanning a QR code presented on that device from another logged-in device. 1
darkassassin07 674 Posted September 12, 2024 Posted September 12, 2024 Having recently installed it to have a look around; I really like the 'Quick Connect' option Jellyfin has. When at the login page for your server, you can select 'Use Quick Connect' which displays a 6 digit code on screen. You can then open any already logged in client (the app on your phone for example) and enter that code. The new client then gets logged in as whatever user was authenticated on the existing client.
