Juanrendon 4 Posted September 8, 2024 Posted September 8, 2024 Today I have experienced problems on my EMBY server, I have a Linux operating system and I have an Opendrive drive synchronized, but it is not playing the content, the Dropbox drive plays without problem, I would like to know if this is from the emby u server opendrive, I clarify that I have not updated the emby server to the latest version
Juanrendon 4 Posted September 9, 2024 Author Posted September 9, 2024 Hello, thanks for responding, The exact problem is that it does not load the content that I have on the Opendrive drive, but if it loads normally what I have on Dropbox, I have plex servers on this same Opendrive drive and it plays without problem, so I don't know what could be causing the problem in emby if the Opendrive mount is ok. It should be noted that it had been working perfectly but today it did not want to work in emby 21 minutes ago, Luke said: Hola, ¿qué está pasando exactamente?
Happy2Play 9812 Posted September 9, 2024 Posted September 9, 2024 But what does "does not load content" mean? Is it just a playback issue and Emby is seeing all the content? Probably need to see the server log also.
Juanrendon 4 Posted September 9, 2024 Author Posted September 9, 2024 9 hours ago, Happy2Play said: Pero ¿qué significa "no carga el contenido"? ¿Es solo un problema de reproducción y Emby ve todo el contenido? Probablemente también necesites ver el registro del servidor. That's correct, it's just a reproduction problem, the content, Emby sees all the content ok, but it doesn't play it, before it worked fine, and from one moment to the next it no longer works, I go back and note that I have that same Opendrive Mount in PLEX and it works normal.
JohnnyTai 5 Posted September 9, 2024 Posted September 9, 2024 19 minutes ago, Juanrendon said: That's correct, it's just a reproduction problem, the content, Emby sees all the content ok, but it doesn't play it, before it worked fine, and from one moment to the next it no longer works, I go back and note that I have that same Opendrive Mount in PLEX and it works normal. Look like i'm not alone. Without transcoding my media can only play on local network or with VPN to the local network. Problem seem to affect all versions not just any specific one. I try on Jellyfin or Flex seem ok.
Juanrendon 4 Posted September 9, 2024 Author Posted September 9, 2024 2 minutes ago, JohnnyTai said: Parece que no soy el único. Sin transcodificar, mis archivos multimedia solo se pueden reproducir en la red local o con una VPN a la red local. El problema parece afectar a todas las versiones, no solo a una específica. Lo probé con Jellyfin o Flex y todo parece funcionar. Hello Johnny Tai, do you also have problems with the content hosted on Opendrive?
JohnnyTai 5 Posted September 9, 2024 Posted September 9, 2024 Just now, Juanrendon said: Hello Johnny Tai, do you also have problems with the content hosted on Opendrive? I host the content on my own server. The problem is that I need to be on the same network for the media to start transfering to the client. My trailers is hosted locally too but it does play fine, only affect the media (movies and tvs) for me.
Solution Juanrendon 4 Posted September 9, 2024 Author Solution Posted September 9, 2024 15 hours ago, Happy2Play said: But what does "does not load content" mean? Is it just a playback issue and Emby is seeing all the content? Probably need to see the server log also. For some reason the problem has already been resolved, it now plays the files in OpenDrive normally, thank you 1
