kientran 0 Posted September 8, 2024 Posted September 8, 2024 I setup DLNA server with Emby, with work perfectly with VLC, my LG TV ( I can see external subtitle). But cannot see any subtile when I am using meta quest 3. In more details, I am using Skybox, DeoVR, 4kVR, they cannot see external subtitles, althroug, I can see subtitle if I am using SMB protocol
Luke 42237 Posted September 10, 2024 Posted September 10, 2024 @kientran Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
hoonlight 18 Posted October 4, 2024 Posted October 4, 2024 (edited) On 9/11/2024 at 5:26 AM, Luke said: @kientran Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Hi, I am attaching the log for the same issue. When playing on the web, the SRT subtitles are displayed without any problem. Only on Meta Quest 3 with DLNA, the subtitles are not displayed. Also, subtitles embedded in mkv files work fine, but external .srt subtitles do not work. User-Agent=Dalvik/2.1.0 (Linux; U; Android 12; Quest 3 Build/SQ3A.220605.009.A1) embyserver-3.txt embyserver-63863628025.txt Edited October 4, 2024 by hoonlight 1
Luke 42237 Posted October 5, 2024 Posted October 5, 2024 17 hours ago, hoonlight said: Hi, I am attaching the log for the same issue. When playing on the web, the SRT subtitles are displayed without any problem. Only on Meta Quest 3 with DLNA, the subtitles are not displayed. Also, subtitles embedded in mkv files work fine, but external .srt subtitles do not work. User-Agent=Dalvik/2.1.0 (Linux; U; Android 12; Quest 3 Build/SQ3A.220605.009.A1) embyserver-3.txtUnavailable embyserver-63863628025.txtUnavailable Hi, can you please reattach the log files? Thanks.
