yocker 1369 Posted September 6, 2024 Posted September 6, 2024 Hello. Is it possible to have two different libraries with different metadata languages pointing to the same movie folder without messing up the metadata for any movies? Fx. some family members are used to danish names of movies but for my self i want to keep them in english. So would be simple for me if i could make two different libraries one in danish and one in english and give permissions accordingly.
Solution GrimReaper 4843 Posted September 6, 2024 Solution Posted September 6, 2024 (edited) 6 minutes ago, yocker said: Is it possible to have two different libraries with different metadata languages pointing to the same movie folder without messing up the metadata for any movies? Not currently, you can lend your support here (and check some alternate solutions around that, found in the same thread): Edit: Edited September 6, 2024 by GrimReaper Link
Luke 42184 Posted September 7, 2024 Posted September 7, 2024 @yockerplease let us know if this helps. Thanks !
yocker 1369 Posted September 7, 2024 Author Posted September 7, 2024 @LukeYes it helped, it answered my question but didn't really get me the function i wanted. Not a complaint but a feature request! Thank you. 1
