Deniax 3 Posted September 5, 2024 Posted September 5, 2024 Hi, For some reason, I cannot get metadata and the movie image in another language then English. For exmample the movie 28 days later on themoviedb.org has a Ukrianian movie image and metadata: https://www.themoviedb.org/movie/170-28-days-later?language=uk-UA Yet, when i set Preferred metadata download language and Preferred image download language to Ukrainian and Country to Ukraine, I still get the movie image and metadata in English
Luke 42184 Posted September 5, 2024 Posted September 5, 2024 HI, did you refresh the metadata on the movie after doing that?
Happy2Play 9798 Posted September 6, 2024 Posted September 6, 2024 Need to see the server log from when item was imported or Refreshed. Quote 2024-09-05 17:43:34.251 Debug App: Running MovieDbProvider for E:\Media\Movies - DB\28 Days Later (2002)\28 Days Later (2002) - 1080p.strm 2024-09-05 17:43:34.252 Info HttpClient: GET https://api.themoviedb.org/3/movie/170?api_key={apikey}&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers&language=uk-UA&include_image_language=uk-UA,null 1
Deniax 3 Posted September 6, 2024 Author Posted September 6, 2024 (edited) Attached my serverlog. What I did is: 1) Restarted Emby 2) Went to 28 days later in the "Ukrianian library" (I have two libaries, one English and one Ukrianian, both read the same movies from the same location) 3) Pressed refresh metadata for 28 days later 4) All data stayed in English What was noticable, is that when I tried to refresh the whole library (Ukrianian one) , it also started a scan for my English library, not sure if that is related (note, this part is not in the log, I tried that before I restared Emby for a fresh log) embyserver.txt Edited September 6, 2024 by Deniax
Deniax 3 Posted September 6, 2024 Author Posted September 6, 2024 (edited) An update: I deleted my English library, having only the Ukrianian left. When I refreshed the metadata on that specific movie, it directly worked. So it seems its a bug: If you have two libraries with 2 different languages, the second library you added lastly, will not download the metadata in that language. It seems it uses the settings of the first library. This is only if both libraries, read the same movie folder Edited September 6, 2024 by Deniax
Solution GrimReaper 4843 Posted September 6, 2024 Solution Posted September 6, 2024 (edited) 6 hours ago, Deniax said: (I have two libaries, one English and one Ukrianian, both read the same movies from the same location) Having multiple libraries pointing to the same source is not supported (though it can - and does - work as long as one's particular about library type and settings) as one/same item cannot have two sets of metadata. As having multiple-language libraries for the same content is currently also not supported. I've just replied to another similar topic, you can check there for alternate solutions and/or lending your support. Edited September 6, 2024 by GrimReaper
Luke 42184 Posted September 7, 2024 Posted September 7, 2024 @Deniaxplease let us know if this helps. Thanks !
Deniax 3 Posted September 7, 2024 Author Posted September 7, 2024 It helps, I will vote on the feature as I think it's quite an important feature to have and in the meantime try out the strm files method
Deniax 3 Posted September 7, 2024 Author Posted September 7, 2024 I use now symlinks, not strm to overcome the problem 1
