Ugnaughts 53 Posted January 30, 2025 Posted January 30, 2025 (edited) ok i got the custom logo triplicated in db so it works in all themes. this app has allot of other features. dont have much time at moment to go thru all details. but tried to make as straight thru as possible. and tested many times. when i get a chance for long. i will create thread for it. with all details. just make sure the embycomp.txt file has correct paths, and put your api in there( its just for shutting down emby properly) the update logo button also updates the paths in your m3u itsself if you change the location of your custom logos folder. only if it can find the path you specified as the from path. you need to make sure your m3u all have same path and its in a folder called logos. after that one time lengthy process. it about minute on a new system to have your m3u custom logos working. EmbyComp.zip Edited January 30, 2025 by joekingcool update screenshot
JIsenhour247 2 Posted August 13, 2025 Posted August 13, 2025 (edited) On 1/30/2025 at 4:00 PM, Ugnaughts said: ok i got the custom logo triplicated in db so it works in all themes. this app has allot of other features. dont have much time at moment to go thru all details. but tried to make as straight thru as possible. and tested many times. when i get a chance for long. i will create thread for it. with all details. just make sure the embycomp.txt file has correct paths, and put your api in there( its just for shutting down emby properly) the update logo button also updates the paths in your m3u itsself if you change the location of your custom logos folder. only if it can find the path you specified as the from path. you need to make sure your m3u all have same path and its in a folder called logos. after that one time lengthy process. it about minute on a new system to have your m3u custom logos working. EmbyComp.zip 3 MB · 1 download what if my custom logos and url's in my custom local.m3u will this still work for me? Edited August 13, 2025 by JIsenhour247
Ugnaughts 53 Posted August 14, 2025 Posted August 14, 2025 On 8/13/2025 at 9:29 AM, JIsenhour247 said: what if my custom logos and url's in my custom local.m3u will this still work for me? not sure what your asking exactly... but if you set all the paths in the m3u for logos to certain folder manually ..... then later you move that folder to new location... then the app will update the paths for logos for you to the new location.
