Gilgamesh_48 1243 Posted September 3, 2024 Posted September 3, 2024 I am trying to use Emby to watch/record iptv m3u streams. I have managed to get what i have working fine and I have three separate M3U files providing streams. If it matters I have set each source to only allow 1 simultaneous stream. The problem I am having is that when I am browsing the guide in the web app (Using Opera version: 112.0.5197.5) most of the time when moving through the guide guide it will randomly reset back to the current time. I have the guide set to get 14 days of data but I am unable to scroll past 3 days or so without the guide resetting to the start. If I use the day selector it will display whatever day I have chosen just fine for about two minutes and then reset back to the start. That is no matter how I get the guide to display any day in the future it will reset to the start after a short time. What i want is simply to browse the guide and have it remain on the current selected time until I cause it to change or otherwise exit. As I see this I am thinking that it somehow has to do with the m3u changing somehow but Emby seems to react to changes a bit too sensitively. I can change the browser I am using if it will fix this. Or I can change most everything else as well. The ability to set and record future programs is not effected except it is hard to get the display to show the future guide for long enough to set a recording but when I have the time i can set a recording 10+ days in the future and it will happen as scheduled it is only the ability to set a future recording that is affected. Along with changing the browser if needed I can also make some changes to the M3Us involved but i have little control over that. Note: This does not happen on any client except the web browser so i can manage the guide and set recordings fine. I just would rather do all my management tasks from the web browser. I am going to try other web browsers but it takes some time and I feel like i am just spinning my wheels rather than making progress. Any suggestions will be much appreciated.
Solution Gilgamesh_48 1243 Posted September 3, 2024 Author Solution Posted September 3, 2024 Nevermind. I just tested with Chrome and it works fine. I have no idea what Opera does differently but Chrome works fine. I do not really remember what made me switch to Opera but I hope it was not too serious.
