codechurn 9 Posted September 2, 2024 Posted September 2, 2024 Is there a way to set the default sort order for folder view? It looks like any nested folder inherit the settings of the parent. Also, if a folder sort order is set, is that per stored per device or per user?
Solution ebr 16306 Posted September 2, 2024 Solution Posted September 2, 2024 38 minutes ago, codechurn said: Is there a way to set the default sort order for folder view? Hi. Not at this time. 38 minutes ago, codechurn said: if a folder sort order is set, is that per stored per device or per user? Should be per user.
bblackmoor 16 Posted September 19, 2024 Posted September 19, 2024 On 9/2/2024 at 2:26 PM, ebr said: Hi. Not at this time. Should be per user. Is there a feature request page where we could vote for this? Having to manually set the sort on every folder is tedious.
Luke 42184 Posted September 19, 2024 Posted September 19, 2024 11 hours ago, bblackmoor said: Is there a feature request page where we could vote for this? Having to manually set the sort on every folder is tedious. Hi, yes just click on that topic that ebr linked to and add your feedback there. Thanks !
