D1sk 4 Posted August 29, 2024 Posted August 29, 2024 https://meinServerde/Items?&ids=16475&serverId=8bc8ae6fe2d946fcbd21cb341832072d { "Items": [ { "Name": "Miwa Kouzuki", "ServerId": "8bc8ae6fe2d946fcbd21cb341832072d", "Id": "16475", "Type": "Person", "ImageTags": { "Primary": "2fc8bcf6609bea971aca7debd742dc59" }, "BackdropImageTags": [] } ], "TotalRecordCount": 1 } If I do the following I get this information Why can't I filter for everything that is type person based on the ServerID? https://MeinServers.de/Items?type=Person&serverId=8bc8ae6fe2d946fcbd21cb341832072d How can I do that?
Luke 42234 Posted August 29, 2024 Posted August 29, 2024 HI, there is a separate api for people. See /Persons.
D1sk 4 Posted August 30, 2024 Author Posted August 30, 2024 10 hours ago, Luke said: HI, there is a separate api for people. See /Persons. Hi Luke I don't really understand how to get the information. I only see Get and person but how do I use the ServerId? https://swagger.emby.media/?staticview=true#/PersonsService/getPersons
adminExitium 356 Posted August 30, 2024 Posted August 30, 2024 Use /Persons?serverId=8bc8ae6fe2d946fcbd21cb341832072d
D1sk 4 Posted August 30, 2024 Author Posted August 30, 2024 1 hour ago, adminExitium said: Use /Persons?serverId=8bc8ae6fe2d946fcbd21cb341832072d https://meinserver/Persons?serverId=8bc8ae6fe2d946fcbd21cb341832072d The file '/Persons' cound not be found.
Solution adminExitium 356 Posted August 30, 2024 Solution Posted August 30, 2024 It's a GET request, not POST.
D1sk 4 Posted August 30, 2024 Author Posted August 30, 2024 (edited) I need more help with the api i try to update the image with an other Example Postman setup: URL: https://meinserver.de/emby/Items/78951/Images/Primary/Upload Method: POST Headers: Key: x-emby-Token Value: Your API token Body: Select form-data Add a field: Key: file Type: File Value: i Select the image file on your computer Input string was not in a correct format. I also don't know I don't understand these API rules when I look at what is in the documentation and what I have to enter for a query is somehow different? Edited August 30, 2024 by D1sk
Luke 42234 Posted September 5, 2024 Posted September 5, 2024 @D1skdid you try comparing your request to what the web app sends for it's image uploads? You can do this using the browser debugging tools.
