nodiaque 62 Posted September 18, 2025 Posted September 18, 2025 Jellyfin convert on the fly to mp4. It's just a container change. There use to be a specific option, now it is enabled based on what you set on the player. For instance, I have an option to use fmp4 which enable hvec and a 1 through hlg profile. Doing so make transmuxing to mp4 with dv not working anymore on my test. So it's off for me.
bjjones 23 Posted October 4, 2025 Posted October 4, 2025 FYI the WebOS 25 that rolled out last week (at least for the C3/G3 series, for 2023 models I'm not sure which others got it) now natively play DV in .mkv containers. Be careful what you ask for, in Emby you used to be able to take a hybrid DV Profile 8.1 with HDR10 fallback file and drop it in a mkv if you wanted it to play as HDR10 or put it in a mp4 if you wanted it to play it as DV. After last weeks WebOS update it now plays as DV no matter which it's in, which seems to be what most everyone was wanting. I for one will miss the ability to pick either/or just by choosing the correct container and I haven't figured out a way to force it to play as HDR10. .
Luke 42233 Posted October 4, 2025 Posted October 4, 2025 49 minutes ago, bjjones said: FYI the WebOS 25 that rolled out last week (at least for the C3/G3 series, for 2023 models I'm not sure which others got it) now natively play DV in .mkv containers. Be careful what you ask for, in Emby you used to be able to take a hybrid DV Profile 8.1 with HDR10 fallback file and drop it in a mkv if you wanted it to play as HDR10 or put it in a mp4 if you wanted it to play it as DV. After last weeks WebOS update it now plays as DV no matter which it's in, which seems to be what most everyone was wanting. I for one will miss the ability to pick either/or just by choosing the correct container and I haven't figured out a way to force it to play as HDR10. . Just to clarify, the change in behavior is actually due to changes in the LG video player. It's not something that we have control over.
nodiaque 62 Posted October 5, 2025 Posted October 5, 2025 I hope this update drop for my older version 1
Moreje 16 Posted October 5, 2025 Author Posted October 5, 2025 I have an OLED B1... and no, DV movie in direct play are still pink/green :( 1
daiv_ 1 Posted October 6, 2025 Posted October 6, 2025 On 04/10/2025 at 23:43, bjjones said: FYI the WebOS 25 that rolled out last week (at least for the C3/G3 series, for 2023 models I'm not sure which others got it) now natively play DV in .mkv containers. Be careful what you ask for, in Emby you used to be able to take a hybrid DV Profile 8.1 with HDR10 fallback file and drop it in a mkv if you wanted it to play as HDR10 or put it in a mp4 if you wanted it to play it as DV. After last weeks WebOS update it now plays as DV no matter which it's in, which seems to be what most everyone was wanting. I for one will miss the ability to pick either/or just by choosing the correct container and I haven't figured out a way to force it to play as HDR10. . That's good news (as far as this thread goes). Out of curiosity, why would you want to use HDR10 over DV? My understanding is that DV was the superior format, but is it a case of a DV master can be worse than the HDR10 equiv?
Moreje 16 Posted October 6, 2025 Author Posted October 6, 2025 (edited) On 10/5/2025 at 12:43 AM, bjjones said: FYI the WebOS 25 that rolled out last week (at least for the C3/G3 series, for 2023 models I'm not sure which others got it) now natively play DV in .mkv containers. Just one little out of topic question: how do you identify WebOS 25 version? I looked everywhere in my TV settings, and all that I found is v. 6.5.3-47 EDIT: found an answer... seems that my 2021 TV is not on the same numerotation scheme... Edited October 6, 2025 by Moreje
muiz 16 Posted October 7, 2025 Posted October 7, 2025 (edited) On 10/5/2025 at 8:55 AM, Moreje said: I have an OLED B1... and no, DV movie in direct play are still pink/green Read some post before this. There are ways to fix this. I have also a B1 Edited October 7, 2025 by muiz
Moreje 16 Posted October 7, 2025 Author Posted October 7, 2025 1 hour ago, muiz said: Read some post before this. There are ways to fix this. I have also a B1 I read about mp4 conversion... i prefer to exclude releases with DV tags and keep HDR only.... I've tried the conversion trick before...too many errors , quality loss , some incompatibilities.... lots of manual interventions not really usefull in an automated setup... but maybe I did not configure well....
bjjones 23 Posted October 7, 2025 Posted October 7, 2025 On 10/6/2025 at 5:21 AM, daiv_ said: Out of curiosity, why would you want to use HDR10 over DV? My understanding is that DV was the superior format, but is it a case of a DV master can be worse than the HDR10 equiv? Short answer is I don't know any better and can't see the difference, some of my usual devices don't have DV capability built in so I've just always just chosen HDR for my library since everything I stream to handles it direct streamed w/no transcoding or tone mapping
muiz 16 Posted October 7, 2025 Posted October 7, 2025 16 hours ago, Moreje said: I read about mp4 conversion... i prefer to exclude releases with DV tags and keep HDR only.... I've tried the conversion trick before...too many errors , quality loss , some incompatibilities.... lots of manual interventions not really usefull in an automated setup... but maybe I did not configure well.... You did not configure well. Works 100% perfectly.
Moreje 16 Posted October 8, 2025 Author Posted October 8, 2025 6 hours ago, muiz said: You did not configure well. Works 100% perfectly. ok, if you say so..
yocker 1410 Posted October 8, 2025 Posted October 8, 2025 22 hours ago, Moreje said: I read about mp4 conversion... i prefer to exclude releases with DV tags and keep HDR only.... I've tried the conversion trick before...too many errors , quality loss , some incompatibilities.... lots of manual interventions not really usefull in an automated setup... but maybe I did not configure well.... If you mean converting mp4 to mkv and vice versa then mkv and mp4 are just containers, as in they contain the data. The data it self (movies and audio) are not touched when converting so will remain the same.
muiz 16 Posted October 8, 2025 Posted October 8, 2025 2 hours ago, Moreje said: ok, if you say so.. Maybe i can help?
s3rgb 2 Posted December 6, 2025 Posted December 6, 2025 Is there a reason why on-the-fly remux to mp4 cannot be implemented? Is there an existing feature request for this change?
Luke 42233 Posted March 5 Posted March 5 HI, we are working on improving this. Thanks for the feedback.
