strikegun79 0 Posted August 29, 2024 Posted August 29, 2024 Hi, I would like to use emby for my media files, but also as offline disc library. Idea is, that I can show my guest all movies, even the offline discs. But that should contain the same infomation like the mediafiles disc type: 4K , 3D, bluray etc. Shown by the cover with cover art -> at the moment I can only do that, by naming the file instead of .disc to .iso and only dvd and bluray are possible. perhaps recieve video- or mediatype over nfo? Show in the movie detail, that it is a offline disc. -> perhaps over cover art? but how? also nice would be to show a user comment or storage place notice How did you guys working with offline media? I love emby, but also my offline media, a combination between them would be great. thanks
Abobader 3484 Posted August 29, 2024 Posted August 29, 2024 Hello strikegun79, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution GrimReaper 4843 Posted August 29, 2024 Solution Posted August 29, 2024 3 minutes ago, strikegun79 said: Hi, I would like to use emby for my media files, but also as offline disc library. Idea is, that I can show my guest all movies, even the offline discs. But that should contain the same infomation like the mediafiles disc type: 4K , 3D, bluray etc. Shown by the cover with cover art -> at the moment I can only do that, by naming the file instead of .disc to .iso and only dvd and bluray are possible. perhaps recieve video- or mediatype over nfo? Show in the movie detail, that it is a offline disc. -> perhaps over cover art? but how? also nice would be to show a user comment or storage place notice How did you guys working with offline media? I love emby, but also my offline media, a combination between them would be great. thanks See: Media Stubs You can also use as an alternative method: STRM Files 1
GrimReaper 4843 Posted August 29, 2024 Posted August 29, 2024 15 minutes ago, strikegun79 said: But that should contain the same infomation like the mediafiles Not all of that would be feasible/possible: 16 minutes ago, strikegun79 said: disc type: 4K , 3D, bluray etc. Shown by the cover with cover art -> at the moment I can only do that, by naming the file instead of .disc to .iso and only dvd and bluray are possible. Emby relies on ffmpeg to provide media info (and CoverArt subsequently on that); as your files are basically blank files, there's nothing for ffprobe to probe/obtain media details; you might wanna take a look at Iconic plugin for an alternate solution/indication as it has certain filename rules. 17 minutes ago, strikegun79 said: perhaps recieve video- or mediatype over nfo? Not supported (and likely will never be due to potential/likely mess that would create). 17 minutes ago, strikegun79 said: Show in the movie detail, that it is a offline disc. -> perhaps over cover art? but how? Emby currently does not provide any means for that distinction (can be somewhat mitigated by using Tags). 19 minutes ago, strikegun79 said: also nice would be to show a user comment or storage place notice As above, there are currently no provisions for user added notes in the UI (can be somewhat mitigated by using Tags). 1
