branson23 2 Posted August 28, 2024 Posted August 28, 2024 I cannot access Emby through the WAN address. The server is configured to allow remote connections, but when I try to access it I get two different messages: 1. The server cannot be reached- try again later, or 2. The server needs to be updated (it already is, to a 4.8.8.0 version) I've installed another emby server before, and this one is available through WAN address, so I presume the router is configured as it should be. Thanks for helping me
Abobader 3484 Posted August 28, 2024 Posted August 28, 2024 Hello branson23, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution rbjtech 5335 Posted August 28, 2024 Solution Posted August 28, 2024 1 hour ago, branson23 said: I cannot access Emby through the WAN address. The server is configured to allow remote connections, but when I try to access it I get two different messages: 1. The server cannot be reached- try again later, or 2. The server needs to be updated (it already is, to a 4.8.8.0 version) I've installed another emby server before, and this one is available through WAN address, so I presume the router is configured as it should be. Thanks for helping me Is the other emby server still active ? You cannot use the same WAN address and port more than once - you need to use an alternative port and your router will then use that alongside the current emby server. So if you have used 8096 before (http) then maybe use 8097 for the 2nd instance (http) THEN you can have both servers active at the same time using the same WAN IP address. 1 1 1
