raylapse 1 Posted August 28, 2024 Posted August 28, 2024 Hi Experts, My TVBox has native 4K UI. The emby android TV client does not looks good as in 1080p. There are two much space between movie posters. i.e. whatever library style I choose (large, middel, auto etc.), the client always shows only 4 posters per line. Can you think about to use responsive layout for the poster wall so that more posters can be shown on one screen??? p.s. I tried android phone app as well, still the same issue. Best regartds, Ray
ebr 16337 Posted August 28, 2024 Posted August 28, 2024 Hi. Have you investigated the image size option in the grid views?
raylapse 1 Posted September 4, 2024 Author Posted September 4, 2024 (edited) Of course I have None of those options solve the problem. With smaller poster size, there are even more space between the posters which looks really ugly. Edited September 4, 2024 by raylapse
ebr 16337 Posted September 4, 2024 Posted September 4, 2024 12 hours ago, raylapse said: With smaller poster size, there are even more space between the posters which looks really ugly. Can you show us a screen shot? What device are you using? Is it truly an Android TV device?
raylapse 1 Posted September 8, 2024 Author Posted September 8, 2024 I can be sure that you are not in 4k UI of the device! In 4k UI, all fonts will be much smaller. Hi guys, just try to get an android TV device with 4K UI support, and you will know what I mean. Not only the poster wall, but there are other iseus as well - for example the progress bar when playing the media is shortened.
Luke 42243 Posted September 8, 2024 Posted September 8, 2024 @raylapse Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
ebr 16337 Posted September 8, 2024 Posted September 8, 2024 On 9/4/2024 at 11:41 AM, ebr said: Is it truly an Android TV device? That looks like probably a knockoff Android device not really certified for TV. The standard app may work better since it isn't using a true Android UI but, also, you may be able to set the DPI values on the device to be more correct and then the other app will work properly too.
Luke 42243 Posted September 10, 2024 Posted September 10, 2024 On 9/7/2024 at 11:15 PM, Luke said: @raylapse Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. @raylapse?
raylapse 1 Posted September 20, 2024 Author Posted September 20, 2024 Hi Luke, As I said at the very beginning, the emby app (for phone) has same behavior with the TV app. i.e. same issues on 4K UI TV box device. If you have Zidoo Z9X 8K, or Shield TV 2019 pro, you can reproduce the issue. p.s. tried Jellyfin on the same device. JF does not have such issue.
Luke 42243 Posted September 20, 2024 Posted September 20, 2024 Quote If you have Zidoo Z9X 8K, or Shield TV 2019 pro, you can reproduce the issue. Hi, yes, both of these. Can you please give a specific example relating to the standard Emby android app?
raylapse 1 Posted September 21, 2024 Author Posted September 21, 2024 Hi Luke Today I found some time to retest the standard app. I have to say sorry about my conlusion before (due to my bad memory) - the standard app does not have the layout issue with 4K UI, it can perfectly show posters with smaller size. However, the TV app looks much pretty than the standard app on TV. If possible, it is stil worth to enhance it to support 4K UI in a responsive way. For the time being, I close this thread as the standard app can solve the most critical issue - gap between posters. 1
ebr 16337 Posted September 21, 2024 Posted September 21, 2024 15 hours ago, raylapse said: it is stil worth to enhance it to support 4K UI in a responsive way. Hi. It already should for true TV devices that report their pixel density correctly. You may be able to correct the DPI somewhere in the device settings.
251643711 9 Posted September 27, 2024 Posted September 27, 2024 On 2024/9/21 at PM3点04分, raylapse said: 嗨,卢克 今天抽空重新测试了一下标准版, 之前得出的结论(由于记性不好)实在是太不靠谱了——标准版没有4K UI的布局问题,小尺寸的海报也能完美显示。 不过,电视应用程序看起来比电视上的标准应用程序漂亮得多。如果可能的话,仍然值得对其进行增强,以响应方式支持 4K UI。 暂时,我关闭此主题,因为标准应用程序可以解决最关键的问题——海报之间的差距。 把字体大小改到320就可以了,不过我是在1080p上的,用手机版
raylapse 1 Posted September 28, 2024 Author Posted September 28, 2024 On 9/27/2024 at 4:18 PM, 251643711 said: 把字体大小改到320就可以了,不过我是在1080p上的,用手机版 请问在哪里可以改字体大小呢
251643711 9 Posted October 13, 2024 Posted October 13, 2024 On 28/09/2024 at 20:01, raylapse said: 请问在哪里可以改字体大小呢 系统设置里,有些系统可以改的,神盾好像不行
