justwondering 14 Posted August 27, 2024 Posted August 27, 2024 I added a new movie to my library in a new folder called "Taylor Swift | The Eras Tour (2023)". It seemed to add successfully, but all of the images showed up as broken and the movie won't play. When I tried to play the movie I got "No compatible streams are currently available." When I opened the broken poster image in a new browser window it showed this error: Could not find a part of the path '/volume1/@appstore/EmbyServer/ The Eras Tour Taylor's Version (2023)/poster.jpg'. It looks like the file name in the error message is missing everything up to the | character. I removed the | from the folder name and rescanned the library, and now everything works. So it seems like an issue with the pipe character specifically. It's pretty small potatoes but it would be nice if this was fixed so pipe characters are supported. Or if that's not possible, perhaps Emby could give a warning when a movie has an incompatible character. It's easy to just remove the | from the name, but first you have to know that's the problem. I'm running Emby 4.8.8.0-724080800, which shows as the current version for Synology. DSM version is DSM 7.2.1-69057 Update 5. Thanks!
Happy2Play 9811 Posted August 27, 2024 Posted August 27, 2024 Will need to see logs but I know on Windows it is considered an illegal character and will assume ffmpeg/ffprobe would probably choke on it also.
Neminem 1623 Posted August 27, 2024 Posted August 27, 2024 (edited) I believe the pipe char is a escape | as in error out if not expected. It will on most os's me an illegal, what is crazy is that the some os's allows it. In some cases its used as a delimiter. Edited August 27, 2024 by JayceDK
Happy2Play 9811 Posted August 27, 2024 Posted August 27, 2024 Surprised TMDB allowed it but TVDB is the same while IMDB uses a colon. TAYLOR SWIFT | THE ERAS TOUR (2023) — The Movie Database (TMDB) (themoviedb.org) Taylor Swift | The Eras Tour - TheTVDB.com So may have to test this one as api data may be an issue. But from a folder standpoint don't see this working even if OS allows it as all the tools will not know what to do with it.
justwondering 14 Posted August 27, 2024 Author Posted August 27, 2024 Log is attached. Looking at Wikipedia's Comparison of filename limitations table, it looks like NTFS and every version of FAT disallow the | character, while pretty much every other filesystem allows it. So anyone using Apple or Unix wouldn't see a problem until it hits Emby. embyserver.txt
Neminem 1623 Posted August 27, 2024 Posted August 27, 2024 (edited) Here is my path for it. Folder : TAYLOR SWIFT THE ERAS TOUR (2023) {TmdbId-1160164} File : TAYLOR SWIFT THE ERAS TOUR (2023) {TmdbId-1160164}.mkv That was scanned in ok Edited August 27, 2024 by JayceDK
Happy2Play 9811 Posted August 27, 2024 Posted August 27, 2024 Ya I just used a dash as I can't use pipe and got and displayed without issue.
Happy2Play 9811 Posted August 27, 2024 Posted August 27, 2024 (edited) Dev will have to comment but with the db path wrong the image processor won't work either. '/volume1/@appstore/EmbyServer/ The Eras Tour Taylor's Version (2023)/poster.jpg'. But for someone that this have never worked for I personally would say the other platforms are wrong for allowing it. ffprobe appears to have issue with path. concat:/volume1/Mothership/Media/Kid Movies/Taylor Swift | The Eras Tour Taylor's Version (2023)/Taylor.Swift.The.Eras.Tour.2023.Taylor's.Version.1080p.10bit.WEBRip.6CH.x264-PSA .mp4: No such file or directory Edited August 27, 2024 by Happy2Play
speechles 2062 Posted August 27, 2024 Posted August 27, 2024 Why would you leave the pipe in the folder name? The names on those sites is for display, not for actual directory/filenames.
