ErikaJ 65 Posted August 25, 2024 Posted August 25, 2024 Good Day, In the Emby channel guide I notice that the listings are color coded for many of the channels. I like that look and I am interested where the guide gets its color information from. Reason because I would like to make a color change for some groups such as "sports", "news", etc. Thank you
Luke 42237 Posted August 25, 2024 Posted August 25, 2024 Hi, are you asking how were the colors chosen? They were WMC inspired as it had a similar feature.
ErikaJ 65 Posted August 25, 2024 Author Posted August 25, 2024 Thanks for the quick response, Luke. Actually, I am asking about where I can go in and edit a color for a group of channels. For instance, let's say the color currently for the "sports" group is red and I want to change all channels in the "sports" group to some other color. Where can I make that happen. My guess is that it's an HTML or Hex code for the color which is fine but where is it located?
Luke 42237 Posted August 26, 2024 Posted August 26, 2024 21 hours ago, ErikaJ said: Thanks for the quick response, Luke. Actually, I am asking about where I can go in and edit a color for a group of channels. For instance, let's say the color currently for the "sports" group is red and I want to change all channels in the "sports" group to some other color. Where can I make that happen. My guess is that it's an HTML or Hex code for the color which is fine but where is it located? There is currently no way to change those colors. We picked them based on what WMC did. Options to control them are possible, but in the meantime the only real way to change them would be using the custom css feature. That will work, although for the web app only.
justinrh 266 Posted August 26, 2024 Posted August 26, 2024 You can modify the web app using CSS overrides.
