weiiihaooo 2 Posted August 25, 2024 Posted August 25, 2024 some hours earlier, Emby update MovieDB plugin to 1.7.8. Emby could not get anything from MovieDB. Then I try to downgrade it to 1.7.7. Everything is fine. Emby is 4.9.0.29.
seanbuff 1357 Posted August 25, 2024 Posted August 25, 2024 33 minutes ago, weiiihaooo said: some hours earlier, Emby update MovieDB plugin to 1.7.8. Emby could not get anything from MovieDB. Then I try to downgrade it to 1.7.7. Everything is fine. Emby is 4.9.0.29. Seems to be working fine in my basic tests. Can you please provide an example where it didn't work? How to Report a Problem 1
weiiihaooo 2 Posted August 25, 2024 Author Posted August 25, 2024 Emby 4.9.0.29 on Qnap embyserver.zip
Happy2Play 9814 Posted August 25, 2024 Posted August 25, 2024 (edited) 26 minutes ago, weiiihaooo said: Emby 4.9.0.29 on Qnap embyserver.zip 426.59 kB · 0 downloads That is for v1.7.7.0 but looks like you cannot communicate with TMDB or TVDB. 2024-08-25 10:50:08.379 Info App: Loading MovieDb, Version=1.7.7.0, Culture=neutral, PublicKeyToken=null from /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/plugins/MovieDb.dll Are you using a vpn? Edited August 25, 2024 by Happy2Play
